Has anyone been able to get a transverter working through the transverter port ona 6400?
Tom Stahl
I have entered the information regarding the transverter; .06 MHz shift (I swear it was 600 Hz on the 6300) I have the frequency set as 144. MHz. The IF is set at 28 Mhz. L0 is 116 MHz I have the TX . Max power is set a 13dB. I am not sure that is correct. The explanation is confusing to me and I have been working with dB levels for years. (and VU units and S-units )
I have tried two separate transverters and the still no joy. so pretty sure It is a set up problem because both of these TV worked on my 6300.
Thanks in advance
-tom
Thanks in advance
-tom
.06 shift on the 6400 = .06 x 1000000 = 60000 hz or 60khz you need .0006 x 1000000 = 600 hz.0
Yep you are correct. Had the shift off and saw it on the pan adapter. That said, I could not get it to work on Simplex either so no shift involved. Opened a trouble ticket because no one responded to if they had used the transverter port or not. Received a priority RMA for expedited shipping back to Austin. You can not beat how Flex stands behind their products. No matter what, I am still a Flex Fan Boy0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
