SO2R AUDIO SETUP
W5AP
I AM TRYING TO SET UP PROFILES WITH MY 6600M FOR SO2R. THEN I SAVE THE GLOBAL (AFTER SETTING UP THE MIC AND XMIT) TO A PROFILE THAT REFLECTS THE TWO BANDS OF INTEREST IE: 80-40, 40-20, 20-15 NAMED 20-15 SO2R RTTY FOR EXAMPLE. ALL WORKS WELL IN N1MM+ SWITCHING BANDS AND TRANSMITTING ALTERNATELY WITH DUALING CQ'S. HOWEVER AFTER THE INITIAL TRANSMISSION, THE MONITOR IS MUTED (EITHER SPEAKER OR HEAD PHONES) THE RIG KEEPS TRANSMITTING ON EACH BAND BUT I CAN'T LISTEN. ANY IDEAS?
You might try pressing the ~ key to un-mute the un-focused radio.
Also, depending on what SO2R mode you are in with N1MM, it might be muting the TX focused radio intentionally. I think "focus other radio" mode will put RX focus on the non-TX radio during TX and should unmute it. But you might have to hit the ~ key to toggle the RX back on.
Matt NQ6N1 -
TNX MATT, I'LL GIVE IT A TRY
Matt, the problem with "focus other radio" is that you can't turn it on then do "dueling cq"
I thought there might be some timing issues in N1MM+ because when I just hit transmit button on either the left or right radio, sometimes i hear a sidetone or in my case rtty tones in the monitor and some times I have to hit the ~ key to get the monitor on. By pushing the A or B tune knob (menu) I noticed that some times the L-R slider was either full left or right. I'll keep playing around....tnx, Jim - W5AP0 -
My suggestion is that you do not use all caps when writing.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
