I am seeing imd or something when sending cw. Is that normal?
Steven Linley
TX/RX CW signal (VFO A only) on 14.012MHz but I also see my signal on 14.008 and 14.016MHz. Is that normal?
Steven,
How are you "seeing your signal"? If you are using the pan in TX monitor then I believe this is totally normal. You are talking about a sensitive receive circuit enabled next to a transmitter. I think you will see lots of little overloads.
Mark0 -
I agree with Mark, you will see very a very wide signal with spurs when looking at your xmit signal in the panadapter . If your concerned, listen to your signal in another receiver with lots of attenuation.0
Also make sure your DSP filters are not enabled which also causes artifacts in the Display0
Yes, I am seeing them in the panafall. OK, I will check it with and w/o DSP filters. Thanks0
Yes, that is totally normal. You have a very high dynamic range spectrum analyzer/receiver inside the same enclosure with a 100W transmitter.0
Ok, thank you0
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
