External display problem on 6400M
Dennis Little
Just tried to connect an external display to my 6400M for the first time and the monitor reads "No Signal". Monitor is an Acer about 6 month old. Plug same HDMI cable to computer and the same monitor and it works fine. Running the latest software on the 6400M. All settings in the Advanced Display seem to be set up according to the users guide. Does anyone have any suggestions.
Did you try turning off flex, power off monitor, then connect monitor and power it up, then re-boot flex?
Sometimes the monitor does not pickup new connection
Yea Jay tried that several times. It's acting like and is saying on the monitor that it's not getting any signal from the radio. I think there's a problem with the radio. The cable works from the computer to the monitor so I know its not the HDMI cable.
ok, go to MENU, then Advanced Display, wait for the graphices control panel to load.
Then select DISPLAY.
Select Multiple displays
Select Clone displays, then save profile.
power down Flex, then reboot. Maybe this will work.0 -
Jay tried your last reply. In Advance Display then in Display and the only thing showing up is Single Display. Multiple Display is not showing up in order to choose it.
Jay I'll call Flex later this morning. Thanks for you help. Tried what you suggested but not seeing anywhere on the advance screen where it will let me clone displays.
Check input on monitor?1
When I first connected my 6600M to a monitor this was my problem. But, after trying a few other things I figured it out. The monitor was in the VGA position instead of Auto or HDMI where it will work.0
Dennis,
What model Acer display is it?0 -
H236hl. It works fine with my computer using the same cHDMI cable.0
Tried auto, selected HDMI AND STILL NO CONNECTION. It’s back at Flex and they’re trying to fix the problem0
I don't see a reason why that display wouldn't work. I understand we have the unit back. We'll check it out.0
Yea Eric when the radio is plugged in to the monitor a message pops up saying "No Signal" can unplug it from the radio and plug it into the computer and the display comes up as it should.
Hope I can get it back pretty quick. It got back to your place yesterday. Any help getting it back quickly would be appreciated.
Eric can u check the status of my 6400m. If its going to take a couple of weeks I’ll tell Matt or Mike to just refund my money. I’ve heard several people having problems with the external display. Just need an answer before my 30 day return policy is up0
Your radio was on the bench on Friday. I'll see what I can find out.0
We should have your radio shipping out by tomorrow from what I understand.0
I have a 6600M and having what sounds like the same problem. Can't get output to go to the 32" HDTV. I've tried the steps in the manual, then all the steps shown above. I used the HDTV just today with the same HDMI cable connected to my Macintosh MacBook Pro and it worked just perfect. I have the HDMI cable going from the Flex to the HDMI 1 input. I've checked the input settings on the TV and they are correct for HD signal throughput.
I confess that it's frustrating to try everything in the manual, all steps here, and other multiple reboots, disconnects, reconnects, and in a variety of sequences. Still NOTHING!
I should be able to figure this out....that is, if there's nothing wrong with the radio.
I have given speeches to groups on every continent except Antarctica, using multiple video formats (mainly NTSC and PAL), in a wide variety of locations where a broad array of projectors, switches, etc. were used. Even in Singapore, where the video technicians were relatively unfamiliar with the translation from NTSC to PAL for large room projectors, I was able to achieve the proper configuration so the video signal appeared on the massive screen. So, you might imagine that I'm shaking my head because this seemingly straightforward process is stumping me.
Radio Serial # is 0818-0646-6601-2641 running Hardware Version 2.1.33.106
The TV is a Hitachi 32" HDTV with 2 HDMI ports. I have used both ports, switched them several times, rebooted several times (with connection sequences rotated each time to ensure that I've covered every combination of reboot configurations). Nothing!
Any advice on what I should try now?
Thanks so much...and I am a THRILLED owner of this amazing radio!
--Dr. Larry S. Anderson, NN5O
Founder/CEO, National Center for Technology Planning
Assoc. Prof. (Ret), MS State University Instructional Technology
Tupelo, MS 38801 (birthplace of Elvis)0 -
Larry I tried everything that I thought I could and even had Flex reps help me to no avail. Had to send the radio back to Flex. They have sent me a new radio and it should arrive tomorrow. Love the radio BUT I think there is a problem with some of the rigs. Flex reps told me that not all the radios have this problem and they are working to solve this issue. I think they got a hold of some faulty components. Just put in a Help Desk ticket and Flex has been good about contacting me in a short period of time. Good luck!
Hello
I have the same proble with my Flex 6400M Maestro as i connected the HDMI from the radio and to the PC monitor which has VGA and HDMI input and i tried every thing but i can not see the radio on the monitor ..
any idea..
many thanks
regards
Joe 9H1GT0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
