Power Genius XL Power Connector?
HCampbell WB4IVF
There was some uncertainty a few months back on the PG XL power connector:
https://community.flexradio.com/flexradio/topics/no-rf-ground-connecter-on-power-genius
What is the final production connector/matching plug configuration (amp side)?
- C19/C20?
- C13/C14?
- Other?
Howard
It's a C13/C14.1
So flex is including the connector now? I thought we had to supply our own.0
You get a power cord with an unterminated end. Supply your own plug, or do what I did and get your own cord set.
https://www.amazon.com/Lynn-Electronics-C13620P15A-10F-60320-C13-10-Feet/dp/B0093WFT5C/ref=sr_1_6?ie...
It says 10 amps but I haven't had an issue.
Thanks much, Ria! I installed a dedicated 240V circuit for the amp, but it is a ways from where the PG XL will be located, so I’ll probably need a longer cord.
Thanks again,
Howard
I use a 10 footer. Works fine, even steady sustained output like MSK144 on 6 meters and FT8 on 160.0
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
