Witch Norton or McAfee for 6600 M
Brad
Brad Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
Have new computer(Win 10) that came with McAfee, but using Norton on my other computer. The new one will be for Ham Radio and the 6600M (if it ever gets here)only.
  • Jeffrey Kerber, N3VE
    Jeffrey Kerber, N3VE Member ✭✭
    edited September 2018
    Brad, I am only using the built in Windows Defender.
    Jeff
  • Bryan  N8WD
    Bryan N8WD Member
    edited February 2018
    eset, plays nice in the background
    https://www.eset.com/us/
    Bryan
  • Tim - W4TME
    edited April 2019
    Neither.  Both cause a lot of problems we get in support.  I am just using Windows Defender and do not do careless things over the Internet.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited July 2018
    Hi Brad,
    I've used a number of AV tools including Norton, Mcaffee and Symantec over the years.  They all seem to cause problems at one time or another.
    With Win10 I've been using Windows Defender and Malwarebytes and had good luck and no issues.  Malwarebytes gets along with Windows defender and does catch things that Defender misses.  The "real-time" protection is one example.  Some web pages look safe but you can't always tell.
    Curious to hear if others have also used and been happy with the Defender and Malwarebytes combination.
    Al / NN4ZZ
    al (at) nn4zz (dot) com
    6700 & SSDR-W  V 2.1.30
    Win10
  • Varistor
    Varistor Member ✭✭
    Consider the Bitdefender network appliance that protects your entire network.
  • Tom W3FRG
    Tom W3FRG Member ✭✭
    I have been using WEBROOT Secure Anywhere for several years without any issues on my Radio PC's running Win 10.
    Tom W3FRG
  • Brad
    Brad Member ✭✭
    edited July 2018
    Thanks all. Am going to take Tim's advice and get rid of McAfee and use  Windows defender. As am not using that computer except for  the  6600 M and a few ham software.
  • Oxford English
    Oxford English Member ✭✭
    I second Tim's advice and use Windows Defender. and I also run Malware bytes exclusively on 6 machines running in my house.
    Do be sure that you get rid of Macafee or Norton or any other AV package you have. Most companies do have removal tools available which work properly, download and use them. If you are really concerned, disconnect the Internet during the removal.
    Also download the Windows Defender package before you start.
    When you have finished removing Norton or whatever, REBOOT the computer TWICE, just in case there are stubs which are only removed at start time. Rebooting a second time is just belt and braces but for the extra time involved, worth doing.
    Whatever you do, DO NOT run two AV programs at the same time. If you do, it can cause all sorts of weird behavior and slow running.
    Tim
  • Ryan - NC4RA
    Ryan - NC4RA Member ✭✭
  • rediffmailsupport
    edited March 2018
    Thanks for sharing the valuable information I also used Microsoft defender antivirus it is the best software for personal computer, but I have faced problem every week MS defender always ask for Gmail even I have already register Gmail id, regarding this I also consult to AOL customer support it provides the mail support service.
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited March 2018
    Tim, any problems running Kaspersky Total Security?
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited March 2018
    Kaspersky is alleged to be spyware
  • Varistor
    Varistor Member ✭✭
    edited March 2018
    Technically Howard’s statement is accurate, but utterly incomplete. It was in fact proven by Israeli, US, and UK law enforcement and intelligence agencies that Kaspersky’s backend infrastructure was breached and the product was used to search for endpoints that contained specific information. Then the identified endpoints were targeted with real data exfiltration tools and methods. Kaspersky itself did not collect the data on behalf of the bad guys. The product itself works very well. SmartSDR has no problem with both Kaspersky and BitDefender. I also use the BitDefender network appliance/firewall to protect my entire network, which includes computers, SDRs, security cameras, ecobee smart thermostats, smart TVs, etc. Most of the malware gets blocked before it enters the network. Last but not least I use OpenDNS as an additional screening tool. Neither I (or the rest of the family) run Windows with admin rights and no ham software has ever ran or will run as admin.
  • Varistor
    Varistor Member ✭✭
    edited March 2018
    A side bar: Most of the systems that have been breached are not the actual target, but only the means of completing the mission or just being a stepping stone. Stuxnet was never about hacking Siemens, it was about Iran’s nuclear centrifuges. Hacking the PlayStation network was a failed attempt to build a distributed supercomputer for cracking encryption. The list goes on. Your personal data has been obtained long time ago, at scale, and enhanced by correlating multiple data points. My clients are paying me well to be paranoid. Let me give you a very crude example to illustrate the CONCEPT of conducting a complete threat analysis: A remotely accessible SDR with high gain directional antennas is a great asset to have in La Jolla, where we have strategic bases used by the Navy, the Marines, and the Secret Service, to name just a few. The SDR can be used for the following: 1) Remote listening post. It’s hard to build a stealthy surveillance site. Using a ham station that has been there for a long time is much more trivial. Hide it in plain sight 2) Use the radio is a command and control node for other on prem devices 3) High power jamming device should such a need araises Again, these are nothing but crude examples to illustrate that your computer or Flex may be used to accomplish missions objectIves that go beyond your personal secrets. You could merely be collateral damage.
