SmartSDR Profile Storage
When a profile is created and saved what directory is the profile saved in and what is the names and formats for those profile files. Is the format of the profile stored files available so that they can be interpreted programmatically by a created utility program external to SmartSDR.
Also is there a way to have an exported profile be sent somewhere besides the radio such as a file.
I am interested in a utility which can display what each profile settings have been made and show what they are using a utility program.
I am thinking of possibly creating such a utility if I can gather enough info and figured I would ask before I explored since I don't want to recreate the wheel if it already is accessible and exists.
The profiles are stored internally in the radio.
You can export/back them up from SmartSDR.
The format seems to be proprietary.0 -
Are they stored in a file in the Flex Radio directory on the computer running SmartSDR?0
Exported persistence and previously saved profiles are exported to a single date stamped file to the PC directory of your choice. I know of no means of reading their contents.
AL, K0VM
Thanks ... now were cookin with gas!0
They are stored in the radio's internal memory.
As Al said, you can export them but there is no way that we know of to read them.0 -
Would be AWESOME if there was a profile editor that you could check off slices you want, frequency, filter, power, etc etc etc. Make a duplicate of one profile and edit and save as another.
Not exactly what your looking for but FRstack by w3ii (aa3rk) does provide another means of managing ( sort of) slices..
AL, K0VM0 -
Profiles and persistence data are stored in a database in the radio. I don't know what sort of storage is used, perhaps flash memory. A "factory reset" will wipe it out and replace the profiles with the standard set of default profiles.
The only way to save Profiles and Persistence data against this sort of loss is to connect to the radio with SmartSDR for Windows, then use the Profile management tools to save a copy to the PC's files. My understanding is that the data is encrypted (I don't know why) but that is the reason they don't offer an outboard editing tool (I would write such a thing if they would let me).
It is good practice to save your Profiles and Persistence data after you make changes to profiles, and before updating to a new version of the software, just in case.
I think a Profile editor would be extremely useful, if for no other reason than to make it clear exactly which parameters are saved in each profile type, and to make it simple to make global changes.
It’s an SD card. That said, it’s not a user serviceable part and not meant to be removed from the radio.0
So that being said you could write an API file which would then get all the settings of a loaded profile then have the program write the settings to a file and do this for every loaded profile in the radio.
Then you could create profiles on your computer made with say an excel spreadsheet and run them through your program which then takes the profile settings from excel and creates an API batch file and saves it.
Then you connect to the radio select the created profile and execute the batch file sent to the radio via the network connection which then sets all the radio settings via API.
Now you can go to the radio profile menu and save a new profile with a new name which matches the profiles you externally created on you computer with the program you developed.
So then it would not matter if it was encrypted or not as long as you can obtain all the profile saved settings by the API program commands to read the radio profile settings once they are loaded.
The API can even load new profiles also I believe so the whole profile thing could be totally automate on the computer program you created.
A big project but could be done and you could even have an overview file to view all the settings of current radio profiles after you program gets the settings via the API.
Always thinking out of the box :-)
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
