SSDR IOS ISSUE
Cal  N3CAL
Cal N3CAL Member ✭✭
edited March 2020 in SmartSDR for iOS
Running SSDR IOS on a IPad Air Mini 4 (Version A2.3.0.0.53)  with a new Flex 6600.  Since updating to the 6600 there is a artifact left on the IOS screen.  Unable to get rid of this blank box?  It's always there.  Any ideas?
Cal / N3CAL
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited March 2018
    Cal Is your radio working?
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2018
    Bill,
    Everything on IOS seems to work ok but that blank window is always there.  It never goes away.
    Cal/N3CAL
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    Have you rebooted the ipad?  That is power of and then power on. i have had similar type of issues with other ios apps and reboot usually clears it up.
    if that does do the trick, then next thing to try is deleted iosssdr and then re-install it
    the app stores know you have paid for it, so you should see a simple 'get' to download it again.
  • Bill -VA3WTB
    edited March 2018
    Cal, is it not linked to the radio that is not working?
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2018
    It links fine.  The display is only issue.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2018
    Deleted the app and re-installed seems to have fixed the issue.  Thanks...
    Cal/N3CAL
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    great....
    glad that worked out for you...
    cu on the bands
    Paul K3SF
