SSDR IOS ISSUE
Cal N3CAL
Running SSDR IOS on a IPad Air Mini 4 (Version A2.3.0.0.53) with a new Flex 6600. Since updating to the 6600 there is a artifact left on the IOS screen. Unable to get rid of this blank box? It's always there. Any ideas?
Cal / N3CAL
Cal / N3CAL
Cal Is your radio working?0
Bill,
Everything on IOS seems to work ok but that blank window is always there. It never goes away.
Cal/N3CAL
Have you rebooted the ipad? That is power of and then power on. i have had similar type of issues with other ios apps and reboot usually clears it up.
if that does do the trick, then next thing to try is deleted iosssdr and then re-install it
the app stores know you have paid for it, so you should see a simple 'get' to download it again.0 -
Cal, is it not linked to the radio that is not working?0
It links fine. The display is only issue.
Deleted the app and re-installed seems to have fixed the issue. Thanks...
Cal/N3CAL
great....
glad that worked out for you...
cu on the bands
Paul K3SF
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
