Flex 3000 will not power on.
kb3byw
My Flex 3000 will not tune on. When I push the power button in the button goes in a fan turns on but the blue light will not light and what I'm assuming is a relay does not engage.
Chances are that an internal fuse has blown. Open it up and check.0
On the power plug make sure all wires are pushed in to make good contact, there are 2 red and 2 black, sometimes they pull out a bit. Push them in all the way.
Upon startup just after you push the power button you should hear 2 clicks very close together.0 -
Send to your nearest flexradio servise center..have one and it needed work onit done...over here i sent it to flexrepair europe in de..got it back as new..regards.de francis(ei3gqb)0
Could also be a firewire card/cable or port issue. Try another card / cable and make sure the cable end are correctly inserted. If this fails, then send it to your nearest service centre.
I will check the power wire, the fuse ,and the FireWire card and cable over the weekend. Thanks for the suggestions.0
Like I said, there should be two clicks on power on. If you hear just one, it may need service. The firewire cable or card will not stop it from powering up.0
Mine did something similar. Once the case was off, it would turn on just fine. One of the front case screws was just long enough to touch the board under the switch side. I put another washer under it as a shim and all is well. n5gkv0
I hear both clicks, the fuse is good. I took the cover off and powered it up and the blue light came on. I turned the radio off and and turned it on again and no blue light.0
Even if the blue light does not come on will it connect and you can run PSDR?0
No go0
I really don't know what could be the problem, I have had a 3000 for 12 years, so I know the radio really well, but this has me stumped, sorry.0
Thanks for the help. I'm going to pick up a fuse tomorrow if I can find one. I looked at the fuse it looked like it was ok I checked and there was no voltage across it.0
I pulled the fuse and checked it and it is good.0
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
- 918 Genius Products
