Will not run on battery at all, has serious problems with Wifi 6 feet from router
I got this used the other day from you guys. I'm not sure I even got all the parts I'm supposed to have.
Regardless, the unit will not run unless its plugged in, yes, I left it on charge with the unit turned off for 4 days, the behavior has not changed.
Unless its plugged in the unit will not boot up properly, wifi doesn't work and so on as you would expect with a dead battery.
Additionally, are their supposed to be antennas on this? The back of mine has damage around one of the holes in the rear near the top, what is that for? The other one has what looks like aluminum foil over it, is this normal?
Was this supposed to come with a microphone?????
I paid nearly FULL price for this, so its not like it was a huge bargain and I should expect this stuff.
Please get back to me.
Peter
Peter
What Radio do you have that has a battery in it??? My Maestro has a battery.. is that what you have??0
I take it you mean an external battery in the Maestro? In that case the battery will not charge in the unit. It has to be removed and charged separately. As far as I am aware the Maestro does not come with a battery and is user supplied.
Tim VE6SH
This one has a battery and it won’t hold a charge. This is a Meadtro0
OK. Maybe I misunderstood. The battery will not charge in the Maestro. It has to be removed and charged directly.0
OK this is weird, I just opened up the back to take the battery out to charge it, there is no battery that I can see. Yet with no AC hooked up it does run. Where is the 5 VDC battery kept then?
Thanks!
Peter0 -
The 5v battery is just to maintain the settings. It will not run the Maestro. You will need to purchase a battery separately and charge it externally. If you search the forum there are some recommendations for external battery packs.
Tim VE6SH
Thanks Tim, I gather I've been running the unit off the display battery. I'll noodle around here and see if I can find one. Still does the Meastro need Wifi antenna?0
That is the battery that keeps the processor in the Maestro alive. You need to run the Maestro off of the wall wart power supply or an internal battery which you need to supply. Do not try and run it without one or the other as it will drain the processor battery and the maestro will not boot up requiring a trip to flex to fix.0
Do you have a recommendation for a supplemental battery?0
There is an internal battery, and a battery that you take out to charge. the internal battery keeps the Maestro alive.0
The one I haved they don't make anymore. Do a search here for Maestro batteries and you should get some info.0
I am using Mogix batteries. Cannot recall the size, but if you search this forum there should be a number of options.
Thanks I got one, found it. Don't know why it didn't come up the first time ... probably a typo, in any case as usual you guys are superb thanks again!
Peter0 -
No Wi-Fi antenna required. It is built in.0
These batteries work perfect in the Maestro https://www.amazon.com/gp/product/B01641KC3I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 73 Bill VA3QB1
Zendesk has a recommended battery list too.
https://helpdesk.flexradio.com/hc/en-us/articles/210311883-Suggested-Battery-Packs-for-Maestro
#Flexradio73, Jay / NO5J
I recommend you also read the manual for the Maestro.
Here is a link to find the Maestro and other downloads including the manual.
http://www.flexradio.com/support/downloads/0 -
I did0
The “aluminum” over the hole is a warranty sticker. You would need to remove or puncture it to take the case apart. That way Flex can tell if the Maestro had been tampered with or not. The Polanfo 20000m battery packs on Amazon work well and last about 4 to 4 1/2 hours each. Flex decided to not allow charging of the battery packs inside the Maestro after all the issues with LiPo battery charging with hoverboards. They do not want liability if there were an issue. Flex opted to use off the shelf battery packs since they are inexpensive and the user could get multiple packs. Keep in mind the maximum size requirement for the battery pack is 6” x 3” x 0.75”. You also want to get one that is auto start, meaning when the Maestro turns on the pack starts providing voltage out. Some packs require you to hit a button to turn them on. Dave wo2x0
The Maestro does not come with a microphone. That is an option.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
