Increasing the number of antenna ports in Power Genius
Tom
PG has only two antenna ports which is rather disappointing for an amplifier in this price range.
Due to a high cost, I do not plan to buy an Antenna Genius and look for other options, considering:
> Hardware cost noticeably lower than an Antenna Genius
> Tight integration with Flex 6000 series and a Power Genius including optional ATU
Can someone offer some practical solutions?
I expect that this topic may be of interest to other future users of PG.
Tom, SP7WT
Tom, SP7WT
If you had ordered last year you would get the free tuner genius or antenna genius. Tuner genius will have multiple ports. I think 3 if I am not mistaken.0
While I wish it had three antenna ports, I believe Tuner Genius will only have two.0
That is incorrect. Please refer to the newsletter sent out around the beginning of January. It even has a pic of me next to my amplifier and station...
TUNER GENIUS SPEC
- 2000W
- Matching SWR range minimum 1:3
- LAN/CAT controlled
- Auto, semi auto and manual tune modes
- Can be used and controlled directly with Power Genius
- Can be controlled from the Windows Application as a standalone device
- 3 antenna outputs
- Has 4 relay outputs controllable from App (optional)
It is great that the tuner now has three outputs! I didn't receive the newsletter so I was unaware of the change. My info was based on an email exchange I had with Flex back in late May 2017.0
Yep, some things have changed. I am beta testing the amp. That said, this is public info...0
Thank you for your clarification, Ria. Yes, I ordered the PG last year and three antenna outputs most likely will be sufficient for me.
Tom, SP7WT
Just to clarify, it looks like Rita said the tuner genius has three ports not the power genius. Am I correct?0
Hi - my name is Ria (not Rita).
The Power Genius XL has two ports configured as SO2R. This means that Input A will go to output A and Input B will go to output B. This configuration is fixed, meaning input A cannot transmit on output B and vice-versa.
The Tuner Genius will have three outputs and one input, so it can be used as a tuner and an antenna switch.
With this configuration you can have true SO2R and four antenna ports, but you may have to reconfigure your antennas differently.
Antenna genius is different as it allows you to map any input to any output. I'm taking the tuner genius but I may go with an antenna genius in addition.0 -
Thanks that makes sense. Ria. Please excuse my typo on your name.1
RF-Kits B26-RF-2K+. 4 auto antenna switch (programmable ). ATU, touch screen, remote with VNC, etc.0
Doesn’t do native SO2R though. That’s important to me.0
Doesn't do 6 meters0
I am getting the Antenna Genius 2x8 switch to go with my Power Genius amp. That way I can have any two of my antenna active at same time with the 6600 and PG XL. More antenna ports than I have antenna but gives best flexibility. I only need a tuner on one of my antennas. Dave wo2x0
It does 6M at 1kw0
Dave - Just curious. Are you planning on running both your antennas in through your PG XL amp? If so the amp is only capable of passing one signal path through (at a time), so I question how will you plan to have two antenna active at the same time? Unfortunately the un-selected port connections on the PG-XL do not allow a pass-thru. Or have I overlooked something?
Using the Power Genius XL with the 6600 allows you to have two active antennas to two different slices at the same time. The 6600 has two spectral capture units. Think of it as two completely separate receivers.
Amp input A goes to output A and amp input B goes to output B.
Now tie the two amp outputs into the new 4O3A 2x8 switch and you can have any two antennas out of a total of eight active at the same time.
For example, I have a resonant 5 band Yagi (10,12,15,17,20 meters), and resonant 30 meter dipole, and a G5RV for 40 & 80 (with tuner).
With the above combo of 6600, PG XL, and 2x8 antenna switch I can be on 20 meters on the Yagi and 30 meters on the 30m dipole. Or 30 meters on the dipole and 40 on the G5RV. All at the same time.
You can only transmit on one band at a time though.
Makes remote operating easy!
A poster above said that the PGXL will only pass one receive signal at a time. I'm puzzled by that comment. If true, that is a big problem. Right you can put in exotic antenna switches which would over come this I guess. But, it would be a ton easier if the amp passed two receive signals at once, even during transmit, you then could use band pass low power ones at that, between the amp and the radios. The Expert SPE does pass two signals and even during xmit one of them is live.
Peter
Ria is quite correct, It definitely does 6 meters, not sure how I missed that, can't edit that post to correct it either.
Peter
“A poster above said that the PGXL will only pass one receive signal at a time. “ Nobody has said that and if they did it would be incorrect. Both SO2R units pass receive signals and are independent. Otherwise it couldn’t be SO2R because the idea of SO2R is to listen to another radio/SCU while transmitting. What is true is that PGXL can only transmit one signal at a time. SPE’s implementation is different in that they have an “SO2R” port which is a common receive antenna port which is switched to the non transmitting radio. This is quite different from true SO2R in the PGXL.0
The amp passes two receive signals to the radio simultaneously (during rx of course). Think of the PG XL as two separate amps. It has an A and B side. You can even have the amp connected to two different radios at the same time. I’ve tested with the Flex 6600 to the A side and an Icom 7600 to the B side. Each with their own CAT and PTT connections. The Flex obviously via Ethernet and the Icom via CI-V. Now take a radio that has two SCUs like the 6600 or 6700. You connect antenna 1 of the radio to input A on the amp. Antenna 2 to Input B. So whatever antenna is connected to output A of the amp will be connected to the receive slice using antenna 1. The antenna connected to output B will be connected to slices using antenna 2. There is some filtering in the 660@ and Power Genius XL and depending on antenna spacing and bands of operation you may or may not need external filtering. Dave wo2x0
I’ve found often I don’t even need external filters with the 6700 when doing SO2R.0
Ummm yes a poster DID say it:
KF4HR
"Dave - Just curious. Are you planning on running both your antennas in through your PG XL amp? If so the amp is only capable of passing one signal path through (at a time), so I question how will you plan to have two antenna active at the same time? Unfortunately the un-selected port connections on the PG-XL do not allow a pass-thru. Or have I overlooked something?"
So who is or isn't correct?
Regarding the SPE 2kFA you are correct. I'll add to that, that when you xmit, the antennas are swapped, so you always xmit on the main system, but during xmit you'll listen on the other one, that is the receive antenna.
Peter
Ria, how far apart physically are your antennas and what power level? Might save me a bunch of money and hassle if they are similar to mine.
Peter0 -
I replied to KF4HR indicating how the PG XL works. Again .... think of it as two separate amps. a side to one radio (or first SCU) and B side to second radio (or second SCU) simultaneously. As Ria stated, you can only transmit on one band at a time. Dave wo2x0
OK Dave got it. Yep no single amp could xmit on two different antennas, bands simultaneously, well maybe one day eh? I think you have the amp, and I think our posts were near simultaneous in posting. I see two different radios ICOM and 6700 so that's pretty clear its receiving at the same time as xmit.
Would be nice if the thing ships soon!
Thanks again all, these forums are a wealth of bright folks and data.
Peter
I have had the amp since November, about the same time Dave got it (maybe a day after). I run SO2R in contests with it. To simplify matters - it’s like having two amps where they are interlocked so only one transmits at a time. As far as spacing goes, I have between 200-300 feet between antennas but some of my antennas are less than 100ft away. I do use the 5B4AGN filter sets to clean up the transmit signal. Operating at the same time on any combo of two bands of 160, 80,40, 20, 10 needs that extra filtering, particularly during transmit between exciter and amp. Receive filters like what the 6600 (and 6700 to a lesser degree) have are only half of the story. You want to suppress the harmonics before they get amplified. That said PGXL does a great job already. You can even use stubs for a cheap yet effective solution. When running contests I’m usually on 40+80, 80+ 160, 40+160 or 20+15 (and when 10 opens, 20+10). During the day I always try to keep a radio on 20. 20+15 can run pretty much without external filters. The rest it gets iffy.1
‘Ria thanks that’s very helpful. Did you get your amp back yet after the recent mods? If so has it continued to run well? Peter0
Unfortunately details of testing are under NDA. You can ask sales any questions about the amp. But I cannot say anything further. Ria0
Related question, if PGXL is powered off or in standby does input one go to ant 1 and input 2 to ant 2 as default. Thinking remote site with amp powered off and antenna genius following 6600 slices a and b on input 1 and input 2.
Thanks and GL Ria!!.
No. It’s a disaster. They short to ground when communication is lost. Mine fried itself yesterday.0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 191 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 955 Third-Party Software
