Slice Master 6000 v0.9.20 now supports WSJT-X
I've just uploaded Slice Master 6000 v0.9.20 to https://github.com/K1DBO/slice-master-6000 The README there is a good place to start if you are a new or prospective user.
If you are already following along you might be interested to know that automatic configuration and launching of WSJT-X is now supported.
Getting multiple instances of WSJT-X running with your radio has never been easier. Just tell Slice Master when to launch it. Whenever switching into DIGU mode works for me. Make sure your slice has a DAX audio channel selected before you attempt to launch. Also, each instance needs to use it's own configuration. By default, each slice is set to use a configuration based on the slice name. You can choose to use one of your existing configuration if you like, or even make a new one by selecting <new>, typing a new name, and pressing Enter.
If you do use an existing configuration be aware that Slice Master will adjust the soundcard and UDP server settings. So you might need to change them back if you want to use that configuration again from outside of Slice Master.
I've made some cosmetic changes to the Mix tab too.
Each slice now shows a signal strength meter along with the level and pan controls. Not only is it fun to watch, but I find that it's a handy way to know which slice is making all the noise when trying to focus my listening with the mute and solo buttons.
Please enjoy responsibly.
--Don
--Don
3
This should be fun.
I saw you corresponding with Laurie
Any chance that you will be adding fldigi?
Zack N8FNR0 -
I would second Fldigi!1
A lot of people also use DXLab Winwarbler too for RTTY and PSK.0
Don, one fantastic piece of software for the Flex community. This makes setting up CW Skimmer very, very easy and it's automatic after the setup. Unbelievably easy. Thank you0
I put a bit of effort into including JTAlert support into this release but I couldnt get it to behave reasonably enough. If Laurie is willing to fix a bug or add a startup option I'll be able to enable the option for launching JTAlert with each WSJT-X instance. For now, you'll have to manage your JTAlert instances on your own. I find that minimizing them when not is use works well enough.0
I'd say there is a good change of adding fldigi. My current thinking is that it might be more fun to add support for midi controllers first. But fldigi is on the to-do list.1
Winwarbler is also on the to-do list.
Thanks Bob, you're welcome.0
Yes Don some nice work!
I've been using SDR-Bridge for years and was hesitant to make a switch, but with each successive Alpha version I've tested I've run into more and more problems getting CW Skimmer to load properly. I intalled Slice Master this afternoon, and even though it took a few minutes to get things working properly, it's up and running. What a cool program! I think I'm going to be very happy with it, as i'm one of those guys who continually jump between frequencies and modes. Great job!
Thanks Mike.0
Thanks for the kind words Rick. Now I have to ask though... those few minutes it took to get things working, is there anything Slice Master could have done to speed up the process? One of the goals is to minimize the setup time as much as possible.0
Slicemaster is great. Made getting CWSkimmer and WSJT talking to the radio much easier for my new 6400. My compliments on your work Don.
Zack N8FNR0 -
No, I think whatever 'difficulties' I may have encountered were due to my setup here. I have two Flex radios, a 6400 & a 6500, and when I switch between them, I sometimes forget I need to reselect the proper radio in CAT. Once I got everything straightened out on my end all went well. Slice Master is almost too simple. It seems there ought to be more settings to have to mess with, but the dang thing just works!0
Great!
But two radios? While Slice Master looks like it might let you switch between them, I'm just a few thousand short of being able to test that myself!
More settings? Have you played with RIT/XIT? How about all the stuff on the Sync tab or the secrets hiding in the Mixer? But dont worry... even more settings are on the way.0 -
Thanks Zack... I'm glad it's working out as intended!0
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 67 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 269 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 29 Aurora
- 230 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 767 Peripherals & Station Integration
- 986 Third-Party Software
