6600M bandwidth center/width controls
I believe the once the passband width is set, you should be able to move it around without it changing. The controls work as expected in the "high / low" mode.
Wonder if your knob inner and outer ring is too close and turning both? Several guys have had issues.
Rich, no the knobs are mechanically fine and work perfectly in "high/low" mode.
This problem only occurs in the "shift/width" operating mode entered by pressing the outer knob in to switch modes. I think it is a software issue.
So is this in CW mode or another mode Geoff? I assume you meant to say press the inner knob in to switch modes and not outer?
On phone it collapses the width when it gets to the carrier frequency and does not cross it. You would think it would just stop. I have never had a use for that filter mode in phone though.
Rich
In SSB mode. I haven't tested it in CW mode yet. When I said outer I meant the one sticking further out from the front panel. You are right it is the inner, concentric, knob that changes the mode between "low/high" and "shift/width".
Geoff, you might be a good guy to explain to me why you would use this filter mode in SSB? I find it frustrating that Flex does not associate the filter mode type with the mode.
It seems to me that center is a method for tuning modes with a center carrier like CW and AM.
I would agree that it should not change the width when you hit center but don't understand why you would want to use this mode on SSB anyway.
Rich
Rich, sometimes it is more convenient to set a receive bandwidth for SSB and then be able to slide this bandwidth window slightly up or down in frequency to eliminate QRM from above or below this frequency window without having to individually adjust the upper and lower frequency limits.
Is there a way to make the RX filter controls default to LOW/HIGH instead of SHIFT/WIDTH?
I find that I mostly use the LOW/HIGH feature of the bandwidth controls most of the time and would like that to be the default mode instead of having to press and hold the button every time I use the radio to switch from SHIFT/WIDTH to LOW/HIGH.0 -
Geoff,
The filter widget in SSDR has the same annoying behavior. In SSB mode the filter cut next to the carrier can not be shifted past the carrier frequency. CW however works as expected. Someone made an assumption that since there is no SSB signal below the carrier the filter low cut should not extend below the carrier frequency. So the shift control widget mostly only shifts in one direction away from the carrier. You can shift it about a full 10k away from the carrier but not the other direction making the shift function mostly unusable for reducing high side QRM. You have to manipulate the high cut instead and end up changing the filter bandwidth. This doesn't effect performance, actually improving it by eliminating noise on the other side of the carrier, so one could argue that this is the right way to do it, but having to change filter bandwidth for high side QRM is not as convenient and defeats half the purpose of a shift control.
Another problem with the filter widget is that when you try to shift left or right, you almost invariably end up moving the mouse slightly up or down, the up/down motion also changes the filter bandwidth. Using the widget invariably leaves you with some random bandwidth setting that only approximates what you intended.
Compared to other radios It is a bit clumsy.
T.R. WR4T
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 942 Genius Products
- 346 Tuner Genius XL
