Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Flex 6xxx and digital modes via remote connection
Hello all,
I've purchased a Flex-6400, though it hasn't shipped yet. I've been working with a buddy of mine to set it up at a remote location, but recently in speaking with him. He is unsure if digital modes will be usable since the radio will be remote and no PC at that location.
Is it possible to do digital modes via SmartSDR from a remote location or is a PC required at the remote location with a VPN connection to it? (or even a Maestro at some point in the future)
- 69 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 86 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 67 DAX
- 278 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 555 Maestro
- 14 FlexControl
- 722 FLEX Series (Legacy) Radios
- 149 Power Genius Products
- 117 Power Genius XL Amplifier
- 10 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 404 Third-Party Software
I'm not sure how it will consume your bandwidth...
I do recommend, if you're not experienced with networking, that you consult with a friend to set-up the Raspberry Pi. It's not difficult if you understand a bit of Linux and networking.
Most of us use OpenVPN. A google search will yield a lot of tutorials. The software is free and well supported.
The reason Flex has not implemented DAX and CAT remotely is due to bandwidth issues many users would experience. That would lead to a LOT of support calls to Flex which they cannot solve since the only solution is to provide more bandwidth.
You'll love the FlexRadio!
Mack
W4AX
Alpha Team
I'm knowledgeable in Linux, OpenVPN, and R-Pi. It will be setting up the Flex to work with it is where I may end up with questions.
Do we know what the bandwidth requirements are for supporting this?
I am in the process of evaluating the feasibility of changing three QTHs from Elecraft equipment to Flex. The Elecraft stuff has performed excellently -- except for "connectivity" and remote operating.
For this to work for me I'd want the logging software/etc (DXLab) to be at the control location, which may be either of two of the three QTHs. (One is a commercial tower site in a rather austere location -- but with great bandwidth. No control/operating from there.)
I understand there are issues using DAX via SmartLink (sad). However, I use Peplink routers to form persistent VPN connections between the three locations. The routing tables are automatically updated immediately after the VPNs are connected. Each QTH has its own subnet -- 192.168.10.0/24, 192.168.15.0/24 and 192.168.20/24, respectively. One can, for example, use a browser to connect to a IOT device/etc running on a different subnet -- without ever leaving the VPN/local network environment.
I might mention that I'd need to do CW, digital modes and phone, the last being least important. I use Winwarbler (part of the DXLab Suite) to send keyboard CW (although I decode with my ear) and for RTTY. WSJT-X should also run from the control QTH.
So, I guess there are two "big questions" :<) :
1. Suppose I have a Maestro or computer running SmartSDR at one QTH. Will I be able to choose a Flex 6XXX radio located at another QTH and still enjoy full "Flex functionality?"
2. Would there be any issues operating remote 6XXX radios with the DXLab software at the operating QTH?
A negative answer to either of these would suggest a "no go" vis-a-vis the contemplated migration. A work-around could be considered so long as it is not a kludge or "fiddly"as the Brits say. ;<)
Adde
It also seems to me that the "audio issue" raised here is a non-starter. Audio traverses the internet all the time. With decent bandwidth, a little QOS, and a good CODEC, it generally works quite well, in spite of the fact that the internet was designed as "best effort." And, when it fails it certainly is *not* FRS' fault! Hence, I don't understand the reticence of FRS to enable inter-LAN connectivity. But, that's what I'm here to find out: "Will Flex work for me?" [Side note: So far, it looks like "maybe some day." We'll see. I'm still learning. :<) ]
I've worked some great DX with the K3s and their RX on CW is incredible. But, comparing my P3s to what FRS has to offer is nonsensical, for a single example.
Rest assured, I'm not too interested in sending $15-20K or more of stuff to the used market and buy all new. But I'll do what I have to do. Unfortunately, I know not a single person in my area who uses FRS in a sophisticated way (not talking about just rag-chewing on 80 phone). Never even seen it "work!" So, I'm "investigating." I bought a 6300 and a Maestro and am, shall we say, "learning," albeit far more slowly than I'd like.
I appreciate your comments! :<)
usually i run IQ @ 48k for 2-3 hour for CW skimmer and remain of the day whit DAX active on 1 slice
this is my internet usable for last couple of day 18,19 was very active > 8hour of EME operation
noting do for reduce bandwidth like slow down refresh rate or else
this include "causual" home internet usage of 6 to 10gb per day
so as long you stick to 1 slice VPN is manageable and have no limitation
if need low bandwidth for digital mode whit multiple slide put computer remote and access it trough teamviewer / anydesk ,this is what i doe for "monitoring" eg cw-skimmer that send me spot via telnet or WSJT-x trough pskspotter
p.s. make sure that if someday you use audio CODEC to really chose it very carefully ,
most of it destroy digital mode or extreme weak signal ,try to do digital mode whit RCForb ;-)
At this point, it appears that whatever I do will be "fiddly" and a kludge. Likely I will simply give up the thought of remote operations. Just not enough time to make it work -- trying to adapt old technology to new uses.
Again -- thanks for your comments!
http://www.pivpn.io/
I can setup a VPN on a Raspberry Pi 3 in less than 30 mins that works the first time. Just forward the correct port on your router and your done.
server that you can then use with a free Open VPN client on your Windows or MAC laptop.
It all works out of the box.
I too played the RR and K3 route for Remote... TOTAL KLUDGE.
I am a computer nerd from way back and even I found it less than obvious to get working reliably albeit I have always been able to figure it out in each location if I put the effort into it..
I am not a CW guy but I do understand that RR works very well with CW. I can't comment on Flex.
RR Works Ok for the use case where you have a fixed remote and a fixed base but if you travel around the world like I do, it requires far too much extra **** to pack in my luggage. By contrast, for my use cases, all I need to do with Flex is schlep my iPhone or iPad and I am on the air from anywhere in the world... too easy.
Bottom Line; The K3 was NOT PURPOSE BUILT for Remote... when the 6000 line was. With SmartLink finally working, it totally blows away RR for ease of use and especially lack of additional **** to schlep.
Plus.. while I do like the spots on the display of the P3 with the K3 when you add NAP3, and for a while it was the major reason I liked the K3, The puny display on the P3 pales in comparison with the SSDR display and especially the spots of the display with SSDR for IOS which again is now the superior product.
BTW.. I am starting to wonder if our anonymous friend, Varistor has ever owned or even operated a Flex rig. If he had, I seriously doubt he would still be promoting ancient 20th century tech in the 21st century.
