SmartSDR 6400M/6600M download to Stand Alone Radio
Wayne
What is the oldest version of SmartSDR which can be downloaded to the 6400M/6600M radios for stand alone use which works?
Will 2.0.17 be functional and downloadable to the rigs?
How about version 1.x.xx's? Where people say the ANF worked better than it does now?
2.1.30 is the oldest. Anything older will not support the hardware in the 6400/6600/6400M/6600M.
2.1.30 had an issue with setting power to 100 watts and not adhering to persistence. You are better off staying at 2.1.32
The secret to the ANF is to keep it as LOW as possible, I find that with it turned on and set to "0" (ZERO) works best with the least amount of distortion.
Same with "NR" and "NB", I run the "NR" here about 2 to 3, You can find a sweet spot for your location for these settings but just start LOW and only use them when you need them.
I don't think there has been a change in the DSP Filters that I have noticed for quite a while in the release notes or using the Radio so even if it did work with the 6400 / 6600 I don't think you would find much difference in the DSP Filtering in the older versions.
73's
Bret
WX7Y
Thanks I have a flex 3000 and noticed much more flexibility in the settings.0
They have been doing things under the hood to the DSP that may not be mentioned in the release notes. I have noticed a difference. Yes, a setting of 1,2 or 3 works very nice without being to aggressive. With the ANF I start at 0 and work up till I only hear a small ping, very little distortion, but I think some more work needs to be done on that.0
Even though PSDR allows for more adjustments, they are not all very useful. Most of the time leaving them at default works the best. People have spent a lot of time playing with settings to find the best performance and make them default settings.
How ever, to get the most from your 3000 I suggest visiting KE9NS web site and look at the list on the left side and look at the recommended settings he has.
I have owned a Flex 3000 for 10 years, I found his settings a good help.0 -
Yes I find those features on the flex 3000 work great now that I have found the best settings for my area and moved the flex and coax off the wall that was horizontal to a power line feeding a street light!0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
