Upgrade to SSDR v2 and 6500 - lock up!
Steve Bunting
Hi Everyone,
I have collected a 6500 from an estate sale and immediately upgraded to SSDR v2.0.19 via an ethernet cable. The radio is available in the SSDR Launch panel but clicking on it causes the SSDR to hang. No number of radio or PC reboots can make it work.
SSDR on the same PC works just fine with my 6300 with direct connection, over the LAN or via Smartlink. I assume that this is a problem with the 6500? What so I do next?
Steve, M0BPQ
Steve, M0BPQ
I am using a Flex 6500 and have never seen this problem, ever. I sounds like a disconnection problem.0
Check the version of firmware that is already in the radio , in the Radio Chooser window of SmartSDR v2 , move your cursor over the radio , if earlier than version 1.4, go to version 1.4 , other wise try going to version 1.11.12 first and then you should be able to make the upgrade, and don't load DAX and SmartCAT..
Mine is v2.1.32.104 is that the latest?0
yes it is , and don't forget to do the cold boot of the radio after the update, this can cause some lockups if you don't.
Dudley
Thanks for replies. All my SW versions match so that wasn't the problem
Dudley is spot on here - a hard reset fixed it! Thanks so much.
Next to sort out the unresponsive Maestro.....
Steve, M0BPQ0 -
Steve, If you got ythe Maestro from the same estate sale, and it has been unplugged for a couple Months, then you may need to send it to your local Service Center to have the internal battery replaced.
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
