Help, New 6600 having issues on transmitt, Antenna selection problems, internal antenna relay issues
roger palmer
roger palmer Member
edited March 2018 in FLEX-6000 Signature Series
NO RF output. PTT quiets receiver receiver, but does not engage internal antenna relay.
Shows hi SWR on 6600 output meter, but no RF to external Power Meter. Each time I turn the 6600 ON, I have to manually reset antenna selection to Ant 1. Even though it shows it is selecting that antenna, I must switch to another antenna option in Set Up Menu, then back to antenna 1.
  • James Whiteway
    edited March 2018
     I'm assuming that you have read the manual for setup. If that's the case and you are still having issues, I would definitely contact FRS's Help Desk Monday.
    james
  • Bob- W5TX
    Bob- W5TX Member ✭✭
    edited March 2018
    Roger, if you have a dummy load try it first. If SWR is high the transmitter is likely shutting down to protect amp. If using dummy load either tune the ATU or bypass so it’s not tuned to never never land. If no output and you are sure you have load connected to right antenna port etc then contact help desk at FRS.
  • roger palmer
    roger palmer Member
    edited March 2018
    Flex quickly dispatched UPS to pick up the 6600 for 3 day shipping back for warranty repairs.
    Dudley was quick to respond and his support is greatly appreciated.
