Heil Proset Plus adaptor for 6600M
Gary Johnson
Gary Johnson Member
edited March 2020 in FLEX-6000 Signature Series
I can't be the only one that is trying to connect their Heil Proset Plus headset to a Flex 6600M.  I asked Heil, but they haven't responded yet so I thought I would ask here.  Is there an adaptor available??  It would be crazy to have to cobble together a headset adaptor for the most advanced and capable radio available.
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited July 2018
    I thought cobbling together was what ham radio was all about?
  • Carl N8VZ
    Carl N8VZ Member ✭✭
    edited June 2018
    Flex actually makes an adapter that works with the Heil AD-1-Y adapter. It’s kind of kludgy but it works. I tried it both with the ProSet-IC and the Pro 7. I can confirm that it works. 73 de Carl N8VZ
  • Jim-KB1ZNV
    Jim-KB1ZNV Member ✭✭
    edited March 2020
    GARY, If your Heil headset has a 3.5 TS mono plug for the mic input like my Heil Proset, another person on the forum recommended the below item. You plug the mic jack into the black portion of the Y cable and plug the TRS male into the 3.5 mic input connector.  It works on my 6600M.  The receive portion of the cable I have terminates in a regular TRS stereo 3.5 jack that fits into the 6600M 1/8 phone connector. Don't know if this helps. It only costs 4.95 on Amazon.
    https://www.amazon.com/gp/product/B000068O5H/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
  • Jonathan W0JS
    Jonathan W0JS Member
    edited June 2019
    I own a ProSet Plus! With the two 3.5mm plugs. I am using the 6400M and plug it directly into the radio and turn the microphone bias option off.
  • K3SF
    K3SF Member ✭✭✭
    edited March 2018
    ditto..
    did the same with my Heil Proset...works fine with 6600M
  • Gary Johnson
    Gary Johnson Member
    edited March 2018
    Antennas sometimes for me.  I can build 4:1 baluns and Ugly baluns.  I crimp all of my N connectors though - not interested in PL-259's.  $5K radios ehhh - not so much.  The days of build your own are long past, except with Elecraft - sort of.
  • Stephan
    Stephan Member
    I know this is an old thread, However, I ran into a similar issue with 6400 connecting my Heil mic an ptt. Heil told me I needed to purchase the adaptors directly from Flex. Here are the part numbers.
    PTT adaptor is RCA Plug to 1/4in (6.35mm) TS Mono Jack Adapter, Gold Plated
    ACC-TRS-RCA 1
    Heil Mic - 3 Pin XLR to 1/8in (3.5mm) TRS for FLEX-6400(M)
    ACC-CX0076
