Heil Proset Plus adaptor for 6600M
Gary Johnson
I can't be the only one that is trying to connect their Heil Proset Plus headset to a Flex 6600M. I asked Heil, but they haven't responded yet so I thought I would ask here. Is there an adaptor available?? It would be crazy to have to cobble together a headset adaptor for the most advanced and capable radio available.
I thought cobbling together was what ham radio was all about?0
Flex actually makes an adapter that works with the Heil AD-1-Y adapter. It’s kind of kludgy but it works. I tried it both with the ProSet-IC and the Pro 7. I can confirm that it works. 73 de Carl N8VZ0
GARY, If your Heil headset has a 3.5 TS mono plug for the mic input like my Heil Proset, another person on the forum recommended the below item. You plug the mic jack into the black portion of the Y cable and plug the TRS male into the 3.5 mic input connector. It works on my 6600M. The receive portion of the cable I have terminates in a regular TRS stereo 3.5 jack that fits into the 6600M 1/8 phone connector. Don't know if this helps. It only costs 4.95 on Amazon.
https://www.amazon.com/gp/product/B000068O5H/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
I own a ProSet Plus! With the two 3.5mm plugs. I am using the 6400M and plug it directly into the radio and turn the microphone bias option off.0
ditto..
did the same with my Heil Proset...works fine with 6600M
Antennas sometimes for me. I can build 4:1 baluns and Ugly baluns. I crimp all of my N connectors though - not interested in PL-259's. $5K radios ehhh - not so much. The days of build your own are long past, except with Elecraft - sort of.0
I know this is an old thread, However, I ran into a similar issue with 6400 connecting my Heil mic an ptt. Heil told me I needed to purchase the adaptors directly from Flex. Here are the part numbers.
PTT adaptor is RCA Plug to 1/4in (6.35mm) TS Mono Jack Adapter, Gold Plated
ACC-TRS-RCA 1
Heil Mic - 3 Pin XLR to 1/8in (3.5mm) TRS for FLEX-6400(M)
ACC-CX00760
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
