Can audacity send audio to my flex for direct broadcast?
Richard Adkins
I want to set up Audacity to send my CQ call with the push of a button. Is this possible?
Me doing it the old-fashioned way over and over is fine but, not wearing my voice out with calling CQ all night long would be kinda handy.
If not Audacity, perhaps another method that someone might be able to suggest?
Rick K5RHA
Rick K5RHA
Audacity can do it but it's better if you use a DVK software like K9DUR Voicekeyer
http://k9dur.info/voice_keyer.html
However if you want to do it in audacity set the output device to DAX audio TX, and make sure DAX is enabled in the TX panel. You need to press MOX to initiate transmit, then press play in audacity. What a pain in the neck! Better to use Ray's software above...
Ria6 -
Or you can setup N1MM+ with your CQ call and do everything from the logger.
73, Andreas, N6NU
The neat thing with N1MM is you can set up voice for different contests, or even give numbered exchanges.Even folders for different operators voices. I don't use the incremental numerical changes, but after a long contest it is nice to have a voice left.1
Voice keyer is writen for PSDR? how does one make it work on SSDR?0
It can work on any radio with a sound card interface (DAX) and PTT.2
5 -
For those who run a Mac, use the voice keyer builtin macloggerdx and It has its own recorder too. You will need to also run xDax and xCat and loopback software to get audio path to the flex. Also you can setup up keyboard short cuts too.
If you are using an M model flex you do not need to run dogparksdr as xDax and xCat make the connections to the radio
here is screen shot of my setup
Thanks Ria2
I just downloaded VoiceKeyer, at a glance that looks to be a pretty darned handy piece of software. Thanks for pointing me in the right direction. Rick K5RHA2
A quick easy way to send a CQ is to use the slice recorder, red button, to record your CQ, and then each time you click the Green button on the slice it will announce your CQ message and if you have the radio on VOX it will key the radio and go out.0
I personally use n1mm, but find not having a voice keyer inside smartsdr a weakness of the ecosystem.1
I agree Salvador as you could use Flexcontrol to sent the info which always has focus on controlling the flex.
Andrew GM0UDL0
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 703 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
