Second slice CQ Skimmer error 1450
AH0U
AH0U Member
edited March 2018 in FLEX-6000 Signature Series
Slice A works fine slice B set like A gives error code 1450 unable to start... no matter what audio I/O device I select I get the same code... slice B is streaming and DAX IQ is set to 2 and things seem to look per NN4ZZ’s guide... what am I missing?
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited March 2018
    Try the new Slice Master application.  Slice B seems more reliable than SDRbridge for a second slice.
    Andy K3UK
  • Andrew O'Brien
    edited March 2018
    Slice Master did the trick ?
