SmartSDR Cat Software User's Guide with Bookmarks
Hi All - Two days ago I posted the file for SmartSDR-Software-User-Guide with Bookmarks.
In this thread I will provide that link as well as a new link for SmartSDR-CAT-User-Guide with Bookmarks.
In this case the index was setup to direct you to the page indicated however you must always get back to that page to select another page. A simple bookmark of the index page would do that. I still believe that all these docs should be created with bookmarks enabled as it is so much better for us the end users.
The first link will be for the Software User Guide
https://drive.google.com/file/d/1EfQHahvr3jXq5lmlSMeOa-IpaHQJoxfp/view?usp=sharing
The second will be for the SmartSDR Cat User Guide with Bookmarks
https://drive.google.com/open?id=10dkB9228blmVS3p-8wBYPU4fXvRgGLJX
I hope this helps all.
Ray,
Great work, thank you very much. A quick way into the documentation when needed.
Warren
KC0GU
Awesome job on both. Thanks!!0
I went through all of the documents a few months ago and made this change, but we haven't published some of them since then, so some of the public versions still have the static Table of Contents. All future releases will have the active Table of Contents.
Thank you Ray for another fantastic insert to SmartSDR CAT.
If you keep this up: I hope Flex would consider havig you do their manuals.
Personally, your works are much easier to follow and in many area they are easier to understsnd: For those of us that maybe not be tech savvy.0 -
Hi Dave - The Software Cat does have the links provided but if only the TOC has links you must each time enter the page number to get back to the TOC. Like I said above if only the index page is bookmarked them you could get back quickly. The best way is to have bookmarks added so you can go anywhere in the doc by selecting the bookmark. I provided the file I updated to Matt months ago and he said he would forward it to the people that would take care of it. So I must ask why is it so hard to get something published if you made the changes months ago? I believe the best way to allow all to look thru and study the information is to have both the TOC and bookmarks active.0
Thank you for the comment - FRS does a great job in laying out the manual I have just made it easier to get the area desired with very little effort.
Ray
Thanks for sharing Ray Regards Dan -- KC4GO0
The current SmartSDR CAT USer Guide V2 has bookmarks implemented.0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
