DAX problem
What is the best way to fix
I am running
Windows 7
On a good computer
Flex 6500 is running v 2.1.32.104
I have had several flex lockups with this latest rev smartSDR, so yesterday I did a RE-INSTALL of DAX drivers per TIM’s posted instructions
trying to get N1mm+ going for RTTY test that is first time having trouble with N1MM+
been working great for several years.
I have unstalled and reinstalled several times
DXLAB suite of programs work fine
but i can't get N1MM or wsjt-x to work they were working just fine on Friday
the one major change i made was N1MM+ had problems for contest and
i dropped back one rev as per post on the N1MM board
that should not effect WSJT-X
DAX driver ERROR
another error has occurred while trying to open a DAX sound device
Still no JOY
Thanks 73 de jim wb5aaa
Here is my experience in a nut shell with 2.1.32 and a 6300:
Loaded it on a win 10 machine (actually, 2)
after install, turned radio on
started program and started update
update finished and restarted radio
connected to radio (mind you I was on Lan, not Wan).
With radio and computer cat5'd to a switch then to the router, all goes well, until....
I eventually get a disconnect/lockup which forces a long power button push to dump the radio.
After the third time of that happening, I forced an "update" back to 2.1.30 (yes I did leave that on the machines just in case).
Same event with both a quad core intel Dell laptop and a quad core intel desktop, all cat 5'd to the same switch before going to the router.
Once back to 2.1.30 all went back to "normal", everything still works and I also still have the Smart Link working, which I only tried once with 2.1.32.
One odd thing I found was, you can still run the 2.1.32 cat and dax while running 2.1.30 SSDR with no problems. as long as you only have one instance of cat and dax running on a given machine.
One of two things has happened either one of your DAX drivers has become your windows default sound, which should never happen. So make sure in the Windows Sound properties there is not a green check on any DAX driver.
The other issue is that one of the DAX drivers did not completely finish installing , so just uninstall SmartSDR , be sure to say "NO" when asked if you want to save the DAX drivers.. Then REBOOT to reset the registry and re-run the SmarSDR installer .. You should be good to go after the next reboot..
Dudley
Here are some instructions that often fix DAX errors.
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
John0 -
well, i still have the same problem
when i try to load WSJT-X i get an error
HAMLIB ERROR io error while opening connection to rig ..
and when i try N1MM+ it gives me com 12 not responding which is the correct port
I unistalled smartSDR and i said "NO" on saving DAX drivers
but i installed 2.1.30 not 2.1.32
MR. DUDLEY
i can load DXLAB and everything works fine, RTTY etc.0 -
thanks JOHN
i have tried several times still no luck0 -
Another thing to check -- make sure that you haven't selected one of the DAX RESERVED devices in a 3rd party program. That could also cause this issue.0
ok so i had added a com port 12 but the the CAT COM was com106 so i changed it to com112
now i am not getting error message in N1MM+
BUT when i transmit i get a sig in dax control panel TX STREAM and MIC STREAM
but i am not keying rig and no power out
i have checked all tx and RX devices
i am doing something wrong just don't know this 77 year old brain is not working HI HI HI
thanks ALL i have it working
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
