system boot - "Select a Version"
W8QB
When booting up the 6400M, the user eventually arrives at a screen that displays three soft buttons: Info/Connect/SmartLink Setup. After selecting "Connect", I am asked to select from either of two pieces of firmware, v2.1.32, or v.2.1.30.
Is there a way to configure the radio to make the latest downloaded firmware several as the default so that when I press "connect" the radio will automatically load latest available firmware rather than having to manually select from multiple versions of firmware?
Same thing with the 6600M. I too would like an option to automatically go to the currently installed version. Otherwise, having fun on 20 meters which is a zoo today! And the CW section is worse!
According to user manual page 27 the select a version screen appears only when a new version of smartsdr is available. So to me that means that once you start in a version on the list the only time that screen will appear again at startup is if the radio detects a newer version of smartsdr is available from the mothership it tries to contact when it boots.
Unfortunately I dont have my 6400M yet to verify this on.
Wayne0 -
Tried it on the 6600M. Still requires selecting the version of software to run. I think the option to do otherwise is in SSDR for the PC. I'll have to check.
Thanks James and Wayne. I will follow James' suggestion of looking in SSDR for the PC to see if the option to select a default version of firmware exists there. At this point, my experience is identical to James': each time the radio is powered on, option to select "Run" does not appear unless I manually select from the two available versions of firmware.0
Doug, I tried it in SSDR and could not find an option to auto start the current software version. Maybe, they'll include that in another update.
Hi James, thanks for checking! My previous radio was a K3, which is in addition to my back up, a ic-7300, so I am new to the world of Flex.0
There is logic in the software to auto start the software that runs on the M models (as well as on the Maestros) if certain conditions are met, like not connecting to the radio with a different client, a new version of software is not available, connecting to the same radio (which is always met with an M model), and a few other operational "state" conditions.
If the M model is the only radio on your network and you are not using a different GUI client (Maestro, SSDR Win, SSDR iOs, dogparkSDR) to connect to it and you constantly have to select the latest version of the software (v2.1.32 as of this writing), then there may be something amiss in the logic that is supposed to perform this function.0 -
Tim, this is still not working for me. 6600m is requiring me to select the version after 10 starts (no SSDR and no Maestro).
Also on occasions the radio will get to a point that it has green button and black screen and is available to SSDR but wont bring up the M radio front panel to connect. The only thing I can do is shut it down and start over.
This is not specific to this radio. Happened on the first 6600M I had.
Rich
My 6600M also requires me to continually select the version after numerous times. So as you suggest something is amiss in the software - just a minor nuisance. Everything else seems to run as expected so far after a heavy week of usage.0
Based on my conversations with them, this is still normal. If it occasionally auto-starts this would be also be considered normal.
I think most people would agree that the process could be improved on. Auto boot should be normal with a button in corner that says "startup options" that you may select if you want to revert to an older package.
I have never experienced the "auto start" Tim referenced. Always have to select the version on the 6400M. Process needs to be revised for user with only 1 radio and constantly using the latest version and no update available.1
I guess I will chime in here also my new fresh off the press 6400M this past week also requires me to choose. Not a big deal but it would be nice to skip this and move pass automatically
same issue here,,,0
i have a 6600m running ssdr 2.2.8....and
on startup its return to last setup (profle) that was running when i turned it off....no problem here...
so my question to all having the i startup issue, are you running the latest version of ssdr?
i thought version 2.2.8 resolved this issue....it did for me.
Paul K3SF
Patience grasshopper ... If you start the rig the same way standalone it takes maybe 4 or 5 times I forget the exact number as the rig learns your startup. After it learns then it will boot the latest version and go straight to the panadapter without asking for a version.
If you start your rig in different ways for different reasons such as ssdr for windows or ssdr for ios etc. then it takes longer for it to recognize how to startup.
YMMV.
Also when the rig boots up it always boots up in the same way it was shutdown its called persistence. Therefore you should create profiles which define how you wish to operate, I have a standard profile I load as the 1st thing I do once the rig boots up that way I start at the same place each time and can then choose other profiles based upon which band, mode I am going to operate in, or even it I want to go barefoot or load a different profile for my amplifier.0
My 6400M will ask me to "connect" and then select which SDR version unless my computer is turned off. Then it boots directly to radio using the current version of SDR. I had imagined that this was so the operator can decide whether to use the radio screen i.e. go ahead and run SDR on the radio, or use SDR with the PC using the PC screen, or an iPad with SDR for IOS. Is that wrong?0
I find it depends on what I have last done - if I used the front panel last, it boots right in to the radio front panel. If I used the computer last, it waits for me to decide.0
How can I skip the update when starting0
just bought the 6600m so after 2 years still looks like this issue has not been resolved?0
i always have to select not sure why its even needed if we want to switch versions we know where to go to do it, why does it have to prompt every time you start the thing!0
are you saying we just need to save a default profile and it will then boot up in the right version every time?0
- 361 Community Topics
- 620 The Flea Market
- 8.1K Software
- 44 SmartSDR+
- 6.3K SmartSDR for Windows
- 178 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 268 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 984 Third-Party Software
