No Audio from Microhone....on y 6600
YV5WZ
Good Afternoon....
All seem to be ready with my 6600 at my Shack......so I decided to adjust EQ for my PR40 ( for some reason my profile disappeared)
Connected to dummy load.....10 watts.....clicked on MOX .....TX red lighted...on screen and on 6600.....but.....NO audio ....no compression & level panel was showed........Checked Radio SetUP 20dB is lighted with blue......cable is same I've been using.....plus adapter bought from flexradio......
I decided to give a chance to original FlexRadio FHM-2 Mic........No diference
I said to myself....need to reinstall DAX.....I did According to FlexRadio Procedure.....rebooted.....and try again.....Nothing...
Any Idea? or Should I open a ticked?
George, YV5WZ / PY3ZZZ
How is the PR-40 connected to the radio? The 1/4" balanced or the 1/8" pseudo balanced input?
Also, the FHM-2 is a condenser mic so the mic bias needs to be enabled. Check that setting.0 -
Hello Tim Is on for FHM-2
PR40 is using adaptor from flex 1/4 balanced
Can I see the menus on the right side of the console?0
Here they are :-)
sorry about picture...
No problem. I can see sideways ;-)
Is this for the FHM-2 or the PR40?0 -
FHm-2 is actually connected0
Let's use the PR40 rather than the FHM-2
Connect it to the 1/4" balanced jack on the back
Set the mic input to BAL
Set the BIAS off
Leave the +20 dB on
Enable the option to leave the level meter on in receive so we can loof for signal input
Adjust the mic gain to 50
Turn off DEXP
Turn off MON
And make sure the DAX button on the front console is OFF
Speaking into the mic without keying the radio should show a deflection in the mic gain meter
This is results.... what’s next :-$
7.074 mhz is below voice area of 40m if that matters.1
to dummy load....test indicated by TIm was performed on 7.188 :-)
Cheers0 -
Making progress!
Set the levels so that the mic meter almost hits the red
Turn on DEXP and set the level for 60
Once you have it set, then key the radio and see if you have RF power output
Thank you so much Tim!!! YOU ARE THE MAN !!!!!!! Now time for a **** on me hehehehe Thanks
don't forget to set your mic level correctly before transmit..lol0
Yes, back off on the mic level and SAVE EVERYTHING AS A MIC AND TRANSMIT PROFILE
Yes SIr!!! ...hahahaha ....Now I will adjust the profile...Thanks again
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
