No Audio from Microhone....on y 6600
YV5WZYV5WZ Member
edited December 2019 in FLEX-6000 Signature Series
Good Afternoon....
All seem to be ready with my 6600 at my Shack......so I decided to adjust EQ for my PR40 ( for some reason my profile disappeared)
Connected to dummy load.....10 watts.....clicked on MOX .....TX red lighted...on screen and on 6600.....but.....NO audio ....no compression & level panel was showed........Checked Radio SetUP 20dB is lighted with blue......cable is same I've been using.....plus adapter bought from flexradio......
I decided to give a chance to original FlexRadio FHM-2 Mic........No diference
I said to myself....need to reinstall DAX.....I did According to FlexRadio Procedure.....rebooted.....and try again.....Nothing...
Any Idea? or Should I open a ticked?
George, YV5WZ / PY3ZZZ
  • Tim - W4TMETim - W4TME Administrator, FlexRadio Employee admin
    edited February 2018
    How is the PR-40 connected to the radio?  The 1/4" balanced or the 1/8" pseudo balanced input?
    Also, the FHM-2 is a condenser mic so the mic bias needs to be enabled.  Check that setting.
  • YV5WZYV5WZ Member
    Hello Tim Is on for FHM-2 image
  • YV5WZYV5WZ Member
    PR40 is using adaptor from flex 1/4 balanced image
    Can I see the menus on the right side of the console?
  • YV5WZYV5WZ Member
    Here they are :-) image
  • YV5WZYV5WZ Member
    sorry about picture...
    No problem.  I can see sideways ;-)
    Is this for the FHM-2 or the PR40?
  • YV5WZYV5WZ Member
    FHm-2 is actually connected
    Let's use the PR40 rather than the FHM-2
    Connect it to the 1/4" balanced jack on the back
    Set the mic input to BAL
    Set the BIAS off
    Leave the +20 dB on
    Enable the option to leave the level meter on in receive so we can loof for signal input
    Adjust the mic gain to 50
    Turn off DEXP
    Turn off MON
    And make sure the DAX button on the front console is OFF
    Speaking into the mic without keying the radio should show a deflection in the mic gain meter
  • YV5WZYV5WZ Member
    This is results.... what’s next :-$
  • WayneWayne Member ✭✭
    7.074 mhz is below voice area of 40m if that matters.
  • YV5WZYV5WZ Member
    to dummy load....test indicated by TIm was performed on 7.188 :-)
    Cheers
    Making progress!
    Set the levels so that the mic meter almost hits the red
    Turn on DEXP and set the level for 60
    Once you have it set, then key the radio and see if you have RF power output
  • YV5WZYV5WZ Member
    Thank you so much Tim!!! YOU ARE THE MAN !!!!!!! Now time for a **** on me hehehehe Thanks image
  • Bill -VA3WTBBill -VA3WTB Member ✭✭✭
    don't forget to set your mic level correctly before transmit..lol
    Yes, back off on the mic level and SAVE EVERYTHING AS A MIC AND TRANSMIT PROFILE
  • YV5WZYV5WZ Member
    Yes SIr!!! ...hahahaha ....Now I will adjust the profile...Thanks again
