6700/N1MM No Audio coming from DVK to 6700
Chuck
I am trying to set up DVK with N1MM and 6700. I have a CAT port set up and have Logger+ Playback set to "DAX Audio TX" and "Internal Radio Codec" is checked. On the Config line for the 6700, I have checked "PTT via radio command SSB mode" (That way I can leave "Transmit from DAX" off on the control panel so I can use VOX when no message is sending.) I have set up 16 bit 11025 Hz mono messages in the correct location and names. When I push the F key, DAX TX lights, the rig goes into transmit for the appropriate message length, but no audio goes out. One clue: on the 6700 P/CW control panel the audio in selection has "PC disabled" Many frustrating hours searching. What am I missing? (I am a newbie to Flex and N1MM, so any suggestion will sound brilliant to me!) Chuck, W5PR
Hi Chuck
Make sure you have DAX set as a DX input on SmartSDR. It is the same as you do for Digital Modes.
3 things have to happen to send PC audio to the radio.- DAX Audio TX picked in the application
- In DAX, Make sure that the TX button is pushed and is Blue. It will then say Streaming underneath it
- In SmartSDR on the right side, the P/CW Tab, make sure DAX is selected. This is the button that accepts audio from the DAX TX Audio Stream.This is likely the one you missed.
Mike0 -
Thanks, Michael. I printed your suggestions this morning and went out to the radio shack to check my settings. I turned on Smart SDR, Cat and DAX and the 6700. I pressed an F key and it worked fine! Computers will, be the death of me! After the CQ 160 contest this weekend, I will attempt to make a list of all the settings for myself and anyone else who might have a problem.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
