pause/resume button
edited June 2019 in SmartSDR for Windows
Something I would love to have (but can't find) in SmartSDR is a pause/resume button.  I'd like to be able to leave SmartSDR running on my computer and be able to pause it's operation so I can free up resources to do other things on the computer for a minute or two, and then resume working with the radio.
SmartSDR consumes a fair amount of resource on my PC and makes other resource hungry applications run slowly.
Michael
KM6LHD
Welcome!
  • Administrator, FlexRadio Employee admin
    edited February 2018
    SmartSDR is a thin client so a majority of the process is done by your graphics adapter; the CPU is not doing any DSP processing.  Pausing the application will not release memory because the objects are still resident in memory.  Only closing it will release the resources.
  • Member ✭✭
    edited June 2019
    Releasing memory isn't the issue.  It's releasing the processor resources -- when I am doing nothing in SmartSDR other than letting the waterfall run, it uses 22% of my CPU and a reasonable amount of the GPU resource.
  • Member ✭✭
    Try simply minimizing SSDR and see if that helps.
  • Member ✭✭
    Minimizing SmartSDR helps a bit but not enough.  Thanks for the tip, though.
  • Member ✭✭✭
    Change the FPS rate and sizing of the waterfall/panadapter screen. It can make a big difference in graphics load. SmartSDR, by itself, doesn't do much processor-intensive stuff. It's mostly in the presentation. FPS of 10, increasing averaging, and a small window with, say, 10% waterfall will do wonders for your GPU load.
  • Member ✭✭✭
    As Tim mentioned, the  processor does not do much at all running SSDR. It is the graphics that work hard, Maybe finding a more powerful graphics card?  That is about all the resources SSDR is using.
  • Member ✭✭✭
    Michael, wonder why its taking such a toll on your machine.
    Minimizing mine drops the CPU to 1% and stops the GPU usage totally.
  • Member ✭✭
    Hi Mike
    I have to agree with Tim.  SmartSDR uses very little resources.  What do you have for memory installed?  Also, you can just **** it as it stops and starts up again pretty quickly.
  • Member ✭✭✭
    Thats what I see here.  I can stop SSDR and restart it in a matter of a few seconds.
  • Member ✭✭
    edited March 2018
    what processor and speed do you have in  your system? I have an i7 at  2.08 GHz and with 2 pan-adapters  with a slice in each one FPS Set at 20 and Waterfall at max, Fill on and at Max I'm less than 10% and if I minimize it drops to 5 or less.
    I process video and many other activities with SSDR running.
    To steal a line from a movie and modify it a little bit...
    "I think your gonna need a bigger boat"
  • Member ✭✭✭
    edited February 2019
    FWIW, on my Mac quad-core i7 with 16 Gb RAM, and 1536 Mb video RAM, DogPark SDR uses 18% of a CPU (4.5% per core). On my MacBook Air laptop (core duo and 4 Gb, 256 Mb Video RAM) it goes up to 25% of a CPU (12.5% per core).
    So, in both cases, pretty low loads on the system, but I see the advantage of more video memory.
