pause/resume button
Michael Wheatley
Something I would love to have (but can't find) in SmartSDR is a pause/resume button. I'd like to be able to leave SmartSDR running on my computer and be able to pause it's operation so I can free up resources to do other things on the computer for a minute or two, and then resume working with the radio.
SmartSDR consumes a fair amount of resource on my PC and makes other resource hungry applications run slowly.
Michael
KM6LHD
Michael
KM6LHD
SmartSDR is a thin client so a majority of the process is done by your graphics adapter; the CPU is not doing any DSP processing. Pausing the application will not release memory because the objects are still resident in memory. Only closing it will release the resources.0
Releasing memory isn't the issue. It's releasing the processor resources -- when I am doing nothing in SmartSDR other than letting the waterfall run, it uses 22% of my CPU and a reasonable amount of the GPU resource.0
Try simply minimizing SSDR and see if that helps.0
Minimizing SmartSDR helps a bit but not enough. Thanks for the tip, though.0
Change the FPS rate and sizing of the waterfall/panadapter screen. It can make a big difference in graphics load. SmartSDR, by itself, doesn't do much processor-intensive stuff. It's mostly in the presentation. FPS of 10, increasing averaging, and a small window with, say, 10% waterfall will do wonders for your GPU load.1
As Tim mentioned, the processor does not do much at all running SSDR. It is the graphics that work hard, Maybe finding a more powerful graphics card? That is about all the resources SSDR is using.0
Michael, wonder why its taking such a toll on your machine.
Minimizing mine drops the CPU to 1% and stops the GPU usage totally.
Hi Mike
I have to agree with Tim. SmartSDR uses very little resources. What do you have for memory installed? Also, you can just **** it as it stops and starts up again pretty quickly.
Thats what I see here. I can stop SSDR and restart it in a matter of a few seconds.
what processor and speed do you have in your system? I have an i7 at 2.08 GHz and with 2 pan-adapters with a slice in each one FPS Set at 20 and Waterfall at max, Fill on and at Max I'm less than 10% and if I minimize it drops to 5 or less.
I process video and many other activities with SSDR running.0 -
To steal a line from a movie and modify it a little bit...
"I think your gonna need a bigger boat"0 -
FWIW, on my Mac quad-core i7 with 16 Gb RAM, and 1536 Mb video RAM, DogPark SDR uses 18% of a CPU (4.5% per core). On my MacBook Air laptop (core duo and 4 Gb, 256 Mb Video RAM) it goes up to 25% of a CPU (12.5% per core).
So, in both cases, pretty low loads on the system, but I see the advantage of more video memory.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
