Writelog SoundWave error when using SSB F key messages with 6700
Chuck
I can't get the F key messages to work with WL and my 6700. I have tried recording on the fla and recording with Audacity. I am using the proper setup with Audacity and exporting the messages as wav files. I can listen to them and they sound fine. When I try to send them, I get a "Writelog Sound SoundWave Error" I have expended countless hours on this to no avail!
First, see the WriteLog support page: https://writelog.com/wav-files-for-transmission
Pay particular attention to the wave file requirements:- 1-channel (mono)
- 16 bit samples
- Either 11025Hz (CD-compatible) or, if you change writelog.ini, 12000Hz (DVD-compatible)
The Radio Audio settings should be:
xmit(s) from PC: DAX Audio TX (FlexRadio Systems
DVK mic: DAX MIC Audio (FlexRadio System
rec(s) to PC: DAX Audio RX 1 (FlexRadio Syste
Audio review should be your PC Speakers.
Note that WriteLog uses msg1, msg2, etc as the names for the audio files, however you may name them anything you would like. I use the text that is spoken as the file name, i.e. my callsign is named k0cf.wav, sent exchange for ARRL DX is 59-Italy-Alpha.wav, etc. You must change the name in the CW-SSB-RTTY message dialog in WriteLog to match your file names.
To send the messages, you must have "DAX" enabled in the SmartSDR transmit control panel, and should have PTT set up in WriteLog as shown in the Flex driver documentation.
I have been using WriteLog SSB messages for many years without any problems, and it was very easy to adapt the setup to the Flex. It works great!
Craig, KØCF
Craig,
The one thing you left our is the location of the mic - did you plug it into the Flex or into the computer? The standard Writelog setup is to plug the mic into the computer/soundcard and run everything through it all of the time.
John K4SQC0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
