Flex6600M unusual start up
Leo K0LOT
Only just received Flex6600M last Thursday worked using radio screen and PC Just as described in Guide. But today when started the radio started directly with an active panadapter and not as usual with the select version screen. I am using the latest version 2.1.32. cannot connect PC. Have tried holding the start button and then disconnection power but same response. But if i open the PC start and connect as soon as the radio appears on the app the PC will connect. and get a radio in use block on the radio display.
You can select Disconnect user from the radio, if SSDR is running on the pc and reconnect with the radios touch screen. Same thing if the radio is in control and you wish to start SSDR on your pc. You can disconnect a user from either one.0
ok i will try that
Thanks0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
