Perserverance after iOS App Use
Carl N8VZ
After using the iOS app with my Flex6600M and I return to front panel use of the rig I find that I have to reset both the BIAS for the supplied mic and its profile setting. Everything is still set for the iOS defaults and the iPhone mic profile. Is there a way to exit the iOS app in a manner that will return the rig to the previously used front panel defaults? If not, it seems that this should be added at some point. Thanks for any help anyone can give me on this issue. -- 73 de Carl N8VZ
Reminds me of an old quiz show where your objective was to stump the panel. Did I accomplish that feat? ;-)0
Persistence. Which is a hotly debated topic.0
I guess I used a synonym; I hope people will still understand what I'm a talking about.
Might not be exactly what you look for, but could be a little help on the way.... See this video from Al, K0CN about using profiles... https://youtu.be/xAdz1GRbg9Y
This is a easy way of getting the settings back to where you want them.
73 de Adde, SM0SHG0 -
Thanks for reminding me about Profiles. I'm trying to operate this rig -- at least for the time being -- totally in either "front panel mode" or via iOs app. After reading your message, I did discover that one can save Profiles via >Menu>Profiles without the aid of a computer connection. That is certainly some help, but it would be nice to be able to have the rig revert to the last Profile when you disconnect from the iOS app.
- 112 SmartSDR+
- 944 Maestro
