DD6xxxx Macro command for power level adjustment
Dan KG0AQ
I can't seem to find this macro? Can anyone **** the code? TIA 73
Don't know if you are using CAT based macros. If you are then the link below gives you all the information you need on cat commands.
The following set power at 50
ZZPC050;
http://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/
Yes, that is what I was looking for. I'm am creating macros in DDutil and got confused with the leading DD6 macros used for the signature series radios. Thank you!0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
