DD6xxxx Macro command for power level adjustment
Dan KG0AQ
I can't seem to find this macro? Can anyone **** the code? TIA 73
Don't know if you are using CAT based macros. If you are then the link below gives you all the information you need on cat commands.
The following set power at 50
ZZPC050;
http://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/
Yes, that is what I was looking for. I'm am creating macros in DDutil and got confused with the leading DD6 macros used for the signature series radios. Thank you!0
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
