SmartSDR for iOS always on 20m?
Adde Tjernberg
Adde Tjernberg Member ✭✭
edited November 2019 in SmartSDR for iOS
When I start SmartSDR on my iOS device it always starts up on a frq in the 20m band... Is this a feature or a bug... I would like it to start at the same frq I was on when I closed the app...
(Running v2.1.32 in the Radio, A2.3.0:0.53 on iPhone/iPad)
73 de Adde, SM0SHG
  • Ria
    Ria Member ✭✭✭
    Do you have low bandwidth mode enabled? It will do that if you have that enabled.
  • Adde Tjernberg
    edited February 2018
    I sure did. Thanks! (But is this behaviour a feature? Does it save any bandwith?!)
  • Ria
    Ria Member ✭✭✭
    The default does. It lowers the panadapter rate to low level so it works on lower speed connections.
  • Adde Tjernberg
    I do understand that the panadpter needs a lot of bandwith, but why does it starts at 20m? That can’t be a ”save the bandwith” feature...
  • Tim - W4TME
    Gotta start somewhere.  Seriously, if this is the bandwidth saver setting, we restrict the panadapter bandwidth by not allowing persistence to open up a larger panadapter.
