How do I get SSDR CAT to go to COM4 to use with N1MM Logger+?
Dave KD5FX
Just had to re-install SSDR and CAT assigned a COM49 port which N1MM can't find. How do I get it back to Com 4 where it used to be?
Thanks...
Thanks...
Edit COM port number at WIN device manager0
Use this tool to remove reserved COM ports
http://www.uwe-sieber.de/misc_tools_e...
PS. You can also right click on the CAT Remove button to expose the "Reset FlexVSP Ports" action.
Can't edit com port number on VSP com ports, no option for that in DM.0
NO DO NOT DO THIS!!!!!!!!1
This is the right thing to do. Remove the reserved com ports (https://helpdesk.flexradio.com/hc/en-us/articles/115000504463-Removing-In-Use-Com-Ports-for-Availabl...)
The do a reset on the FlexVSP ports as Mark indicated.1 -
Thanks, Mark & Tim. That worked, removed all those reserved ports. Rebooted and then I was able to set it to 5/15 which N1MM can see. Working great again.
I remembered there was a trick to it last time I set it up but that was long ago and I couldn't remember the trick. 73...0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
