Right and left audio level diversity mode
It would be ideal if this could be adjusted while diversity mode is enabled by the front panel, as it is rare multiple antennas result in equal signal levels.
SSDR 2.1.30, FlexRadio 6600M.
Hi David
This is an issue I have filed several "Help" tickets for. I keep hoping it gets addressed in software updates but so far it hasn't been a priority. I have a 6700 and a Maestro "1" that exhibits the same problem. No front panel volume control of the "child" in diversity mode. Flex has acknowledged the problem but it hasn't made the priority list yet.
Jim
ka7gzr
Hopefully this will be a higher priority now as these radios are marketed as not needing computer control (M models that is).0
Seems like having the option for independent AF level control would be real helpful especially with antennas with vastly different sensitivities or gain.
Yes, that is exactly my situation. Also, when using multiple slices, you often have the volumes adjusted vastly differently. I ran into this as this was exactly my situation, I turned on diversity after closing the second slice, but couldn't adjust the audio level on one antenna, which was nearly muted from previous use. I had to fire up a second slice after turning off diversity mode to adjust volume, then disable and reenable diversity mode. Also, sometimes when listening to signals in diversity mode, one antenna may have more noise and I'll want to turn it down, same problem. I have a amplified wideband loop and a wire antenna for receive. The loop has a significantly higher level than the wire, so an update that addresses this would need to allow adjustment, not just equalize the two. I think a good implementation would be using the left knob to adjust volume for left channel, right knob for right, and add a physical/touch screen button to "lock" them together then the left knob would adjust volume for both, keeping the ratio the same between the two. The same physical/touchscreen button could unlock.0
see manual for diversity adjustments for adjusting diversity audio and agc
agree front panel control would be a lot more user friendly
Paul K3SF
Paul,
Slice A (Parent) Diversity works fine from the front AF control. No need to go to this slider for adjustment. Slice B (child) Diversity can only be controlled by the illustrated slider. It is not controllable from the B front panel control in the Diversity configuration,
The FLEX-6600 is working as designed. I have entered your report as a feature request (#5911)0
Tim,
This is confusing. As you know I have submitted a ticket on this. After discussion with you it was marked as a problem to be fixed TBD. Has the status changed?
Jim
ka7gzr
It was added to the bug tracker to have the issue investigated. I do not determine if there is a defect in the software; that is the responsibility of engineering. it was designated as **** (working as designed) so the issue is now classified as a feature request.0
It looks like this is now a votable idea, so vote away.
Hi Tim, I may be missing something, but I don't see the volume slider in the A DIV tab of the drop-down (from the front panel control on the 6600M). I see pan and so forth, but not volume. Is this intended? There's no way I can find to adjust level of the second antenna/RX, only pan, unless I completely disable diversity, enable the b slice, adjust the b slice level, then disable the b slice and re-enable diversity.0
- 384 Community Topics
- 642 The Flea Market
- 148 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 284 FLEX-8000 Signature Series
- 961 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 799 Peripherals & Station Integration
- 142 Amateur Radio Interests
