Waiting on the 6400M
KB4OIF
Got the spot already cleared for it.
What height did you plan for? The radio is a little higher than 6 3/4". You should plan for 7 inches to be safe.
It's 5 inches to the top of the glass shelf. 8 inches to the bottom of the monitor. Going to move the shelf back about 5 inches on the glass top desk to accommodate the 6400M. I have a similar shelf that has longer legs if needed. The lamp will be moved. The boom will be moved over to the left about 5 inches. The dual band radio will be moved too. Have 18 inches from the front of the desk to the glass shelf. 6400M is 13.1 I believe.
Wish it was April.
Anxious.
KB4OIF John0 -
And you may need more height if you use the feet under the front, witch you likely will.0
Wow. what a rush. Open up my email and had an email from Flex. Opened it up and did not read it properly. It was an invoice and a tracking number. I said WOW!!!!!. then read the fine print. it's for a cable I ordered for the 6400M.
There is more to that story,,why sell it when you could just send it back for full refund?0
Got to look at a real 6400M at the Hamcation today. Bigger than I expected but that's ok. I have since changed the monitor. It will be farther back than the picture. Glass top riser will be gone an a clap mount to the back of the desk for the monitor.
KB4OIF
You are right Bill. It's bigger than I thought.
KB4OIF
Clamp mount did not work. Desk top glass is 3/4 inch too thin. Back to the drawing board.
send a picture after you get things organized?0
Sure will Bill. I have decided on an ACER 27 inch . Just trying to work out the space. If the 13.1 depth includes the knobs on the front , I am going to be ok with 4 inches to spare. I did not anticipate the size of the 6400M. I'll get it worked out.
All I need now is the 6400M.
Here is the spot I am going
to fill with the 6600M I pay for some time ago.
Looking good Fred. My buddy just got his 6600M and loves it. My first Flex.
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
