Wsjt-x config for Flex5000 running power SDR 2.8 and Ham radio deluxe
KB4HL
Help with config of WSjt-x and PowerSdr 2.8 with Ham Radio deluxe
Harry, you'll need VSPE or VSPManager and VAC, depending on your OS. I like VSPE, as it runs without any problems on my Windows7 64bit machine. If you have them running, start MiniDeluxe and then PowerSDR.
Do not use HamRadioDeluxe itself, only DM780, HRDLog and the other subprograms, as MiniDeluxe acts as your server. Then use HamRadioDeluxe as the WSJTX settings, PTT on a separate virtual cable and there you are. Please look at the tutorials listed below. My own is for SmartSDR, but you can follow most of it, except vor VSPE and VAC, which you'll need for PowerSDR.
Vy 73, Alex - DH2ID
http://kc.flexradio.com/KnowledgebaseArticle50362.aspx
https://community.flexradio.com/flexradio/topics/tutorial-setting-up-wsjt-x-with-smartsdr
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
