CAT Control Error with WSJT-X V1.8.0 r8193 to SSDR 1.10.16
Peter Schudel
Peter Schudel Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
Hi folks  I am currently facing a strange effect by using WSJT-X  V1.8.0 r8193 with CAT Control to my FLEX-6300  SSDR V1.10.16.
CAT Settings in WSJT are Kenwood TS2000 9600Bd 8, 2  None
All bands switched in WSJT work correct EXCEPT  20m  14.074 MHz !  In this case the Flex doubles the frequency and jumps to 10m Band to 28.148 MHz. The effect is 100% reproduceable. No work around found.I have tried many different settings (Baudrate, Data Bits etc). Thanks for Help!
  • YV5WZ
    YV5WZ Member ✭✭
    Did you check what frequency WSJT-X has saved for 20m?
  • KB4AAA
    KB4AAA Member ✭✭
    edited February 2018
    Did you try to reset all of the frequencies in WSJT-X. open the settings goto freq tag right click in the working frequencies click reset this will change everything to default values. Also you might want to switch your cat control using the FlexRadio 6xxx rig this is the current preferred rig control for WSJT-X
  • Mike va3mw
    Mike va3mw Member ✭✭
    You may want to try a TS-480 as the radio to see if that solves your problem.
    73, Mike
  • Tim - W4TME
    And you may want to upgrade to SmartSDR v1.11 as it has a LOT of fixes in it, including some for CAT.
  • K9DUR
    K9DUR Member ✭✭
    I am running SmartSDR v2.1.30 and do not see this problem.  Also, I have the wsjt-x radio set to "FlexRadio 6xxx" & the Network Server set to "localhost:5002". -- 73, Ray, K9DUR
