My experience with SmartSDR v2.1.30.103
Ernest
This morning I was listening on 40 meters on how well v2.1.30 was working. For a while I though these guys were pulling a joke on a Flex 6x000 owner: Their description how much time they expend to get their units working.
I decided to do my up date on my 6700 without reading the "Release notes." Or any of the notes on the forum.
One thing I had was lots of time with the flu and nowhere to go.
The old DAX, CAT and v2.0.19 running; I visit the old FR System website and downloaded the software to see what may happen doing it this way. After 4 minutes into the installation it came up with an error "Shutting Down" PSH1VOA - 1.09. However it continue installing itself. It also asked if I wanted to ignore it. I ignore it.
The installation did whatever it needed to do and the next thing I see is asking me to press "Update"
Well, it took very little action in my part and the radio has been working since.
Had I not been sitting in from of the radio, I would not believe it either. BUT TRUE!
2
For me, updates have been pretty trouble free, but I'd definitely get that "Oh S**t" feeling when I saw "Shutting Down" PSH1VOA - 1.09" What's that about? I plan on downloading the latest update this evening, but not before I read the release notes!
You mean the DSP works even better than before?0
Occasionally when updating the firmware, there is a momentary voltage increase on the 1VDC rail that the PSoC catches and generates the error shown. As in the case of Ernst, it is usually benign.
If you get this error while normally operating the radio, then you need to submit a HelpDesk support ticket ASAP so we can investigate the cause.0 -
So last night, I read the notes and downloaded the file. After the update was installed I imported my profiles Absolutely no problems and was back up and on the air within 10 minutes. It really is a very simple procedure that no one should be afraid of doing. Great job FRS! See you in Orlando next week,
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
