What is the purpose of the quick record button?
Richard Adkins
I'm an extremely new user of Flex so please bear with me. What is the use of the quick record button? I can't seem to get it to do anything.
I was hoping it would be an easy way for me to record my CQ and have it loop until someone responded. That doesn't seem to be the case.0
On page 33 of the 1.9.9 manual there is a pretty good description of how the Quick Record works.
Got it! Thank you.
Part (most) of it was user error. Once I figured out that my headset mic wasn't hearing me and only the separate mic was, things seemed to start coming together. I'm still figuring out how to get my headset/mic (Heil Pro 7) to work instead of my separate microphone (Heil PR-40) taking all the tx voice. When I depress the push to talk, only the PR-40 picks up my voice. I can't seem to get the Pro 7 to listen to me. I can hear out of it wonderfully. I'll eventually figure it out. I hope. lol1
You can also use something like Audacity via DAX and use that to play music, or any recording. Works very well and you can record until the cows come home1
Hi Richard,
There is a request in for a "looping" or "black box" recording option. It has 21 votes so far, here is a link where you can add your comments / support and vote.
https://community.flexradio.com/flexradio/topics/black_box_recording_add_a_looping_option_to_the_rec...
Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.11.12
Win101 -
Richard,
Look at your MicProfiles. As you set up a Mic, you can control which Mic input is used.
Depending upon which rig you have.... For example, I have a 6500, and I can select BAL or LINE (uses the Balanced Mic connector on the Rear) or MIC (Front Panel Mic Connector) or PC (which comes via the computer if the "Remote" button is selected) or ACC (uses the 15 pin connector on the back)
These different connectors do not mix audio inside the rig.
You can save numerous Mic Profiles with different characteristics - some for rac chewing, some for DXing or Contesting, some for your boom mic and others for your headset mic.
You can send your Mic Audio from your rig to an external program like Audacity, or to your logging program like N1MM or N3FJP's ACLog or other contesting programs. They will allow you to record audio memory files using your Mic of choice right from the rig. Then you can play them back using the voice keyer function in your logging program. Slick!
As far as the quick record function goes...I use it a lot to record someone off the air and play them back so they can hear their own audio. I also hit it while I am transmitting and record myself so I can hear exactly what my transmitted audio sounds like. If you listen simply with the MON function, you will not hear your true audio because the MON is tapped BEFORE any filtering, processing, or Equalization. The Quick record is an easy way to help adjust your transmitted Audio profile (Mic Profile). Just remember to save the Mic Profile after you have gotten things the way you want.
You can check out some tutorials (slightly dated) on www.Youtube.com/NM9P
Ken - NM9P4 -
Thanks Ken, learned something new today but I usually do from you. Did not know about the difference in Mon audio.1
Thank you very much, Ken. Great answer. I'll do my best to put it to use.0
Thanks, Ken. I did not know that the Mon function was tapped before most processing & etc. That will help me a lot when I get audio comments that there is a problem that I can't hear with Mon ( which has happened).
Brad
KE4XJ0 -
This is all great info! I have never tried feeding a recorded CQ into a rig. Wouldn't you then have to change the mic input from PC to MIC to then answer someone who returned your call?1
If you are using your logger’s voice Keyer, in the logger Setup, choose “DAX Audio TX”as your output device. In SSDR, turn the DAX button ON in the TX control panel, and activate DAX TX in the Dax Control panel and adjust the DAX levels correctly while transmitting with the voice Keyer. You also need to tell the voice Keyer how to apatat the rig, either through a CAT PTT port or via CAT command or VOX. The voice Keyer will send your recorded audio. And your mic will send your live voice using mic VOX or PTT.2
Paul get ready, if you're anything like me I think you will be very happy with the new ways of setup DAX (virtual audio cables) virtual com ports as well make life a little better. They are solid as a rock. No more possibility of RF getting into the audio inputs. Pay close attention when Ken said above about making sure DAX button was selected, that's about the only way you can **** it up is in the little details in your initial setup. Small learning curve it comes in time.0
lol... I just noticed the typo:
"You also need to tell the voice Keyer how to apatat the rig,...."
Obviously, that needs to say "You also need to tell the voice keyer how to PTT the rig...."
I just LOVE the "Auto-Corrupt" on my iPad.....0 -
This "smart phone" is the smartest either. I usually catch my mistakes shortly after I send the post.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 181 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
