Maestro VFO A encoder and Knob
Wayne Westfield
I am starting to look into building a hardware controller for the Flex 6500 and am looking for information on the VFO.
Is the Maestro rotary encoder the same used in the "Flex Control", if not would someone kindly post the part number and manufacturer?
Also it would be helpful to have the same details for the the VFO A knob.
Sorry if this was asked before to the best of my searching it was not.
Kind regards,
Wayne
KG5MGN
Kind regards,
Wayne
KG5MGN
The main VFO knob on the Maestro is for VFO (slice) A. The smaller knob is for VFO (slice) B. I doubt you will get a response with part numbers as Flex does not sell parts for field service of the Maestro unit. They also do not publish a service manual for it for the reason explained above (not field serviceable). Dave wo2x0
Thanks David. However I am not looking to source the part from FRS. They have shared the part numbers for the Flex Control so I see no reason they would do the same here. This is of course predicated on the hopes that someone at FRS reads this post. B0
If you're building your own controller I don't see why you would feel the need to use the FlexRadio part for the VFO encoder. In fact there are better options - the Maestro encoder is only 64 steps per revolution, giving, to my mind, rather poor tuning granularity, whereas there are 400, 600, even 800 step/rev encoders out there at low cost. Search "rotary encoder" on e-bay for any number of options ranging from $10 or so.
The knob is more of a problem. You'll probably want something weighted and fairly large - a typical VFO knob in fact. The most likely source is someone breaking an old transceiver, so again e-bay is the place to look. Most of these VFO knobs have a 0.25" shaft (unlike the Maestro encoders which are smaller). There are plenty of rotary encoders with a 0.25" shaft.
You might get some inspiration from my controller project Blog: https://g3wgvflex.blogspot.co.uk/
73, John, G3WGV
They are not the same as the encoders used in the Maestro. The Maestro uses higher quality encoders.0
Can u share the part numbers Tim?0
You can take a look at here https://iw7dmh.jimdo.com/arduino-flex-controller/hardware/
Consider that the higher pulses/rev ratio is not always the better. Values between 256 and 1024 is good enought to have a good response.
If you like to play with the code you could use some mathematical functions (logarithm) to implement a speed sensitive dial knob instead of a fixed step dial knob.
73', Enzo, iw7dmh
I completely agree, Enzo. 400 pulses/rev works very well with nice smooth tuning. I also implemented a speed sensitive algorithm for zipping up and down the band quickly while still having a nice slow tune rate. But Wayne seems to want to use the Maestro encoder.
73, John 'WGV1 -
Was thinking at least that way I would not need to hunt up a knob to a shaft of some sort. The suggestions above are greatly appreciated. Thanks for the help John and Enzo.0
All the encoders on the Maestro A are e37-vt6980-1 from ELMA:
https://products.elma.com/products/e37-tht-vertical-threaded-up-to-3-ncm
I have not been able to find a source of these knobs anywhere.0
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
