multiple wsjt-x
Takeshi Yamada
Is there any mean to run multiple JTAlerts binding to each WSJT-x's running?
Thanks to FT8, Low band activities are very high and I am enjoying multiple WSJT-x operation for 80, 40 and 30m. Currently, I am using JTAlert for one instance of WSJT-x and the rest of WSJT-x's are subject to eye watching and not so effective - I cannot examine 2 windows in detail in 15 sec.
How other multiple WSJT-x users are managing the operation?
de JI1BNU
Ken Yamada
de JI1BNU
Ken Yamada
You can simply dbl click the Jtalert icon on your desktop for each additional instance of WSJT-X or you can also setup the auto start within Jtalert here is my setup opens (3) WSJT-X and Log40m plus (3) Jtalert. It works very slick Jtalert handles the logging interface between WSJT-X and Log40m on all 3 slices and I run slice 4 as ssb and use Log40m window to log contacts on the fly. And the flex will auto switch TX to whichever slice that needs to transmit.
add to the wsjt-x parameters for slice 2 & 3
--rig-name=Slice_B
--rig-name=Slice_C
optional if you use Log40m for logging. In the setup of each WSJT-X you need to set the UDP server port number different on each instance and Jtalert will handle the rest . Here is my setup
Slice A: UDP 2237
Slice B: UDP 2238
Slice C:UDP 2239
4 -
Thank you for your advice.
I could now run 3 instances of WSJT-Xs and JTAlerts and jump to any of three bands for transmit. I am waiting for v2.X CAT supporting Slice: TX slice - I think v1.X supports it already - for Logger32.
Regards,
Ken Yamada, JI1BNU
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
