6600 Mic and Headset questions to add to my Invoice
YV5WZ
Hello
I've received my 6600 invoice, and some options I could add....so I have been wonder
Microphone cable: Have a Heil Sound PR40 and XLR 3 to 8 pin foster cable, I guess Part Number ACC-8P-TRS 8 pin foster to 1/8" ( 3.5 mm) ....I don't know where I read mic jack had been changed to 1/4 " on 6400 & 6600..... so I guess this is my choice... am I right?
Head-set cable: What is the part to use my Heil Sound Pro 7 ?, I guess same above, although ACC-8P-TRS cable is too short (only 8 inches) to be use with Heil Sound Pro 7 Cable.......am I right?
ATU its a must with a vertical antenna....
GPSDO: I feel dummie about this item....
MARS: I was going to request it.....but now ..with moving plans to Equator.....guess I wont need it
Last One: what's 6300 market value now?...I haven't found any reference ...don't have room for it in my shack
As always, thanks for your answers
George, YV5WZ / PY3ZZZ
On the website it shows that the tuner is standard on the 6600 is that not the case? Also it may be worth inquiring about a trade up on the 6300 as they are usually very fair with the offer. You could check QTH for 6300 listings to base private party value on.
GPSDO is a GPS disciplined oscillator, Its just more accurate than the on board unit (Which can calibrate itself to WWV). It is probably not needed unless you are into the high UHF transverter kind of stuff.
Is it? .....I was thinking it was...but I've received it as an option on the e-mail....I'm not sure now...
Steve, I'm at Venezuela, guess in all country there are two Flex 3000 (YV5FRD, YV5SF), One 6700 (YV5AM) and mine 6300....not much to look around
Thanks Steve for advise, I appreciate it.....I will write to Katie to check it
George
ATU is standard on 6600. If it is listed as 0.00 then you are good. Double check though.
What Steve meant was to check for sale sites like qth.com, QRZ or eHam where you can see pricing to determine if a trade is worth your while.1 -
The PR40 I believe is 3 pin XLR. The 6600 has 1/4" balanced. The 6400 has 1/8" pseudo balanced only.
This is the cable:
http://cart.flexradio.com/Balanced-Line-in-Audio-cable-for-FLEX-5000-Flex-6000_p_20.html
That should work, to connect the 8 pin foster to 1/8" pseudo balanced. It might be a bit short. Why don't you ask Heil if they have plans for a cable for the Flex-6400 and 6600? They might have it in the works. I know Dave WO2X has been working with Julius W2IHY to get his products working with the new rigs.ATU its a must with a vertical antenna....
Not needed, built in.GPSDO: I feel dummie about this item....
You don't need it unless you run transverters and/or just like super accurate frequency and want to spend the extra money. For regular HF operation you are fine. Just calibrate with WWV using the built in calibration function. It can be added later anyway.MARS: I was going to request it.....but now ..with moving plans to Equator.....guess I wont need it
Can always be added later. The radio is modular. MARS is only needed if you operate MARS in the USA anyway, and you need to be a US citizen of legal permanent resident (not sure if you are or not) and resident in the USA. If you end up moving here, you can get it as an option I think.Last One: what's 6300 market value now?...I haven't found any reference ...don't have room for it in my shack
Flex has it listed for $1700 on the website. That's with 2.0 software. If you don't want to deal with selling it yourself, you can call Matt or Mike and ask about trade, as mentioned.
Thank you Ria!!
I did not find any 6300 on sale at QRZ.com nor eHam....:(
I guess Trade in is not an option for me....cause I will pay it as soon a Katie get back to me
Cheers!!
Ria,
I see by the manual that "only" the 6600M has the balanced 1/4" XLR input.
perhaps that has changed?
That's likely an error. Both 6600 and 6600M have it, per Tim:
https://community.flexradio.com/flexradio/topics/balanced-audio-input-for-the-flex-6000-and-flex-660...
Ria Thanks
I took a look on flex web site 6300 for $ 1700 with New software 2.0, but ATU neither mic.
Mine is with ATU and unused mic (just tested for 3 days)
so I guess 1500-1600 would be good deal
Thanks Ria
George
Super!
The ATU is standard on the 6600. Optional on the 64001
Please note that to purchase the Extended transmit filters, you must have a valid MARS or Shares license. And you will still need a MARS TURF file too (no charge).0
Thanks Tim.....Katie answered back to me...and Pay has been done......now the sweet waiting
Cheers my friend
I'd like to stress that if you have questions about your pending order, please contact Sales to discuss the issues. They are the ones who can provide definitive and authoritative answers to your order specific questions. If you can't reach us by phone (we are really busy right now) send an e-mail to sales and we'll answer your questions expeditiously.1
Sir Yes Sir!!!
I opened a **** celebration bottle......
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
