6400M CW transmit sidetone
Has the CW sidetone in the 6400M been improved over the raspy sidetone in the Maestro?
  • ctate243
    ctate243 Member ✭✭
    edited June 2018
    Keith I have been doing extensive alpha testing with the 6600-M and the cw sidetone is quite pleasant from this transceiver.  Assumption would be the same for the 6400-M.
  • Tim - W4TME
    edited January 2018
    Chris' assumption regarding the 6400M is correct.
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited January 2018
    I have a "like new", slightly used, Maestro.  Will there be a fix for the original Maestros?
