key out on Flex 6500 to Elecraft KPA1500?
Paul N6PSE
I have a new Elecraft KPA1500 Amp. On a non-Elecraft rig it is keyed by Key out such as on a K3 without the ACC cable. Which port on the 6500 functions as Key Out, is it TX1?
Thank you in advance,
Paul N6PSE
Paul N6PSE
Paul,
It's TX1, TX2 or TX3. Your choice.
Mack
W4AX0 -
YOu can even enable/disable them individually - plus you can assign different combos to profiles if you're using multiple amps. This is how I (used to) do SO2R on the 6700 with a SPE 1.3K-FA.
Great, it looks like TX1 is enabled by default. I am just checking a few more things and then I will give it a go with the Flex 6500 and Elecraft KPA1500. Thanks Ria and Mack!
Hey Paul I am right here just a phone call away if you have any questions.. nice to see you out here0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
