key out on Flex 6500 to Elecraft KPA1500?
Paul N6PSE
Paul N6PSE Member
edited November 2019 in FLEX-6000 Signature Series
I have a new Elecraft KPA1500 Amp. On a non-Elecraft rig it is keyed by Key out such as on a K3 without the ACC cable. Which port on the 6500 functions as Key Out, is it TX1?
Thank you in advance,
Paul N6PSE
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Paul,
    It's TX1, TX2 or TX3. Your choice.
    Mack
    W4AX
  • Ria
    Ria Member ✭✭✭
    YOu can even enable/disable them individually - plus you can assign different combos to profiles if you're using multiple amps. This is how I (used to) do SO2R on the 6700 with a SPE 1.3K-FA.
  • Paul N6PSE
    Paul N6PSE Member
    edited January 2018
    Great, it looks like TX1 is enabled by default. I am just checking a few more things and then I will give it a go with the Flex 6500 and Elecraft KPA1500. Thanks Ria and Mack!
  • ctate243
    ctate243 Member ✭✭
    edited January 2018
    Hey Paul I am right here just a phone call away if you have any questions.. nice to see you out here
