Flex 6x00 and Micorham Station Master
Hi, i have a question i need to connect my Flex 6300 at my station master made from microham, i have build the cable but i don't know how to set properly the software, anyone can send me some screenshot of his configuration.
Many thanks bye bye
Welcome!
  • Member ✭✭
    edited December 2017
    ciao
    the best approach to drive SM is by flex USB interface+(suggested) USB to Serial adpater
  • Member ✭✭
    edited July 2019
    Ok Don, please call me as soon as possible, many thanks.
  • Member ✭✭
    ok
  • Member ✭✭
    edited July 2019
    anyone can confirm that the followed wiring diagram are correct?
    Pin # Label Description
    TIP TXD CAT DATA output from SM
    RING1 RXD CAT DATA input to SM
    RING2 RTS +12V output, max.1mA. Connected to input power via 10K ohm resistor.
    SLEEVE GND Connected to the system ground and case.
    i don't undestand how to connect the RING2.. i need to put one resistor in the cable?
  • Member ✭✭
    edited March 2019
    Hi Adriano,let me give you more details (the configuration that I have)
    a) on flex/smartsdr configure a CAT cable (see smartsdr cable management section)
    b) Station Master JUMPER SETUP : the RS 232 LEVEL is required  (see manual extract and picture below)
    b) the CAT connection cable  from RS232 to Station master , see below
  • Member ✭✭
    edited July 2019
    Nothing to do in microham router? Many thanks
  • Member ✭✭
    not clear to me, what do you mean for microham router ? what do you need to achieve ?
  • Member
    edited March 2019
    Hi Don, Does your Station Master integrate 100 % OK with the Flexradio with the Yeasu CAT cable? 73 Kari SM0HRP
